Dell Latitude e6410 Bios Password
  • DaveWonder
    • Oct 2014
    • Ghana
    Please, anyone can tell me how to reset dell latitude e6410 Bios Password. I cant remember the Password. #36Y61P1-2A7B is my Laptop no.
    Please help me...
  • shadowcat
    • Oct 2014
    • pakistan
    Re: Dell Latitude e6410 Bios Password
    hi all,..help needed
    i have dell latitude d630,its old password:owvlkuk7
    but i have changed or upgrade its BIOS(mistakely).......now it is totaly blocked........a notification occoured (wron password)........do you help me.......now its:
    system: ‪#‎HHZJ1F1‬-3A5B
    BIOS revision A19
    so, can anybody like to tell me, what should i have to do?
    plzzzz help me
    thanks
    • keeney123
      Lauren
      • Sep 2014
      • 2536
      This might be possible. I did this with an Acer. You would have to take the battery out and disconnect the power cable. Then push and hold down the power button for 30 sec.Connect the battery and power cable and power it up, but go directly to the bios and put in a new password. This is good for one time. After it reaches the OS it will revert to old password.
      • aikita
        • Nov 2014
        • 5
        • spain
        Please help me...
        try this : 1HBMQ673G60ImIc3
        0 = LETTER UPERCASE
        • ahmedbogy
          • Apr 2015
          • egypt
          I have dell latitude e6410 and i need my bios password
          my code is #2f1QQM1-1F5A ,please please help me and answer
          • isidoro
            • Apr 2015
            • spain
            Please, anyone reset my BIOS password
            #CHMS2M1-2A7B
            Thankss!!!
            • trebo
              • 514
              • Wales, UK
              #CHMS2M1-2A7B
              Thankss!!!
              try this, 4TVIn9169khi9cto
              • ahmedbogy
                • Apr 2015
                • egypt
                Please help #2f1QQM1-1F5A
                • psiamak
                  • Mar 2016
                  Hello, new user, same problem with newly purchased latitude e6410.
                  Need BIOS password reset. Tag is: 2Y61SM1-2A7B
                  • Godfather79
                    Dell Latitude 5520 3FE2 Bios password Unlock Request (TGL SuothPeak15) bios
                    by Godfather79
                    Hello everyone in the community
                    Dear Sir,
                    I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
                    Problem details:
                    * Model: Dell Latitude 5520.
                    * Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
                    * Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
                    * Service Tag: (Enter your actual Service Tag from the laptop here)
                    * ​BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....
                    11-08-2025, 10:04 AM
                  • gizaha
                    by gizaha
                    02-13-2024, 07:18 AM
                  • jhanra
                    by jhanra
                    in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, πŸ˜…πŸ˜…πŸ˜…...
                    11-02-2024, 04:19 AM
                  • anlsmith
                    Dell Latitude 5430 Bios Password
                    by anlsmith
                    I am trying to remove the BIOS password for a Dell Latitude 5430 motherboard LA-L591P. So far I think that I have located the BIOS chip but NeoProgrammer says that is detects 3 chips. I have attached the dump from each one. Are any of these the BIOS file? Service Tag: 1DMC1T3. If nyone knows the exact location of the bios chip as well I would greatly appreciate it...
                    08-31-2024, 08:46 PM
                  • YOUCEF4787
                    Dell Latitude 5490 (LA-F401P) - Boots from USB-C only, not from DC Jack after BIOS flash
                    by YOUCEF4787
                    I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
                    Initial Problem:
                    The laptop was completely dead, no signs of life, no power LED.
                    Action Taken:
                    I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
                    Current Situation & The Main Issue:
                    The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly....
                    09-21-2025, 12:19 PM
