Lenovo Ideapad 1 11ADA05-82GV BIOS update
This topic is closed.
  • 90Ninety
    • Aug 2011
    • 100
    • UK Mains Voltage 240V 50 Hz
    Quick question — if I flash another BIOS dump from the same laptop model using a CH341 SPI programmer, will that remove the BIOS password?
    If that’s the case, I’d really appreciate it if someone could share a compatible dump. I’ve attached my current BIOS dump for reference.
    Also, do I need to transfer any serial numbers or other system information from the original BIOS to the new one? If so, could someone point me in the right direction on how to do that?
    Thanks in advance!
    • 21922
    Thanks in advance!
    Your last thread was merged with an existing topic - https://www.badcaps.net/forum/troubl...91#post3755691 .You should have got a notification to say there was a reply to your post.
    Please post the laptop serial number as requested and someone will help.
    • mkdj
      Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
      by mkdj
      Dear all,
      I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
      Here the steps I have taken to fix the laptop:
      - downloaded latest BIOS from Lenovo Website...
      10-18-2025, 03:43 AM
    • akwky
      by akwky
      Hi!
      04-14-2025, 01:56 PM
    • joven016
      Lenovo Ideapad S145 need working bios HELP!!
      by joven016
      Problem is blinking power led only
      i don't know exactly if it's s145-15igm or s145-14igm
      have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
      Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
      Already tested some of posted bios here
      S145-14igm - success but invalid serial and not booting on OS
      S145-15igm - success with serial and some other info in bios but still not booting on OS
      already tried installing new windows but always booting on bios setup
      windows installer flash drive detected on...
      08-21-2025, 10:55 PM
    • AHmad_Salal
      Need BIOS Dump/ROM for Lenovo Thinkstation p500
      by AHmad_Salal
      Hello all,
      I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
      11-28-2023, 05:28 AM
    • mximiliandz
      help bios lenovo ideapad s145-14iil type 81w6
      by mximiliandz
      Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
      06-20-2025, 06:50 AM
