Toshiba L500-1VL bios file
  • amquetzalamestudio
    • Oct 2025
    • Portugal
    infos:
    Toshiba Satellite L500-1VL
    KSWAA LA-4981P
    Rev 1.0
    2009-04-09
    thanks...
  • LBTT1121
    • Nov 2024
    • 904
    • Việt Nam
    Originally posted by amquetzalamestudio
    infos:
    KSWAA LA-4981P
    Rev 1.0
    2009-04-09
    thanks...
    post the original contents of the bios chip..not the update on the website..
    The bios chip must be unsoldered from the board before writing or reading..
    do not use the clip, you may have errors..if you do not have anything to unsolder it with,
    solder wires between the programmer and the bios chip..
    you need an SPI programmer
    • to5it0
      by to5it0
      10-24-2025, 01:35 AM
    • Citymin
      by Citymin
      S/N : 5RNK9FFT70...
      08-05-2025, 05:12 AM
    • m1ch43lzm
      by m1ch43lzm
      Hi everyone
      09-06-2025, 05:47 PM
    • HOHA
      BIOS file for Toshiba Dynabook Satellite Pro C50-J-10M
      by HOHA
      Hi can you help me
      I did not find the BIOS file for Toshiba Dynabook Satellite Pro C50-J-10M
      IP3_TN16S_MB_V30_20210901A
      This is the old BIOS file, it is corrupted​...
      10-20-2024, 08:22 AM
    • nahidmirzayev
      Toshiba Satellite P55T-A5202 BIOS file
      by nahidmirzayev
      Hello, Could you please help me to find bios files (2mb&4mb) for Toshiba Satellite P55T-A5202? I have already downloaded wrong bios files several times. Every time led behaviours are different....
      10-14-2025, 11:48 PM
