Dell Latitude 7400 2-in-1 bios with absolute persistence lock
  • berrylinx
    Workaholic
    • May 2025
    • 13
    • Jamaica
    Dell Latitude 7400 2-in-1 bios with absolute persistence lock, Service Tag: HRPJN53
    Can someone please assist with this please. I've provided two dump files using Xgeco T48, one is the read and default saved and other is the Flash saved option, they're labeled according.
    Thank You.
    • 21986
    try the patcher script https://www.badcaps.net/forum/troubl...79#post3633379
    • berrylinx
      Workaholic
      • May 2025
      • 13
      • Jamaica
      When I run absolutely.mps I get this error in the pic below. Yes, bios file has been put in same folder and renamed locked.bin
        • 21986
        try this bios
        • berrylinx
          Workaholic
          • May 2025
          • 13
          • Jamaica
          Originally posted by SMDFlea
          try this bios
          Ok let me test and get back to you in a few hours
          • berrylinx
            Workaholic
            • May 2025
            • 13
            • Jamaica
            This worked perfectly.
            On initial boot it restarted several times which is normal, then it booted straight to bios setup and i permanently disabled Absolute Persistence.
            i then reloaded Windows and everything seems to be working perfectly, I'm actually responding to you from the same laptop.
            Question #1: I have 6 more of these laptops coming in with the same issue, can I use this same bios file you provided to fix those as well?
            Question #2 Can you direct me to some information or software so that i can learn do these modifications myself?
            Anyways i really appreciate the help and the prompt responses.
            • LBTT1121
              • Nov 2024
              • 1062
              • Việt Nam
              used for 6 laptop , file clearME
              • berrylinx
                Workaholic
                • May 2025
                • 13
                • Jamaica
                Hey so I haven't received the other laptops to test that last file you sent as yet , but as i get to test i will certainly post here. In the mean while i have another Dell that has a bios password i need cleared, I have attached the backup below. Thank you in advance.
                Model: Latitude 7400
                Service tag: 9JH30R2-CF1B
                • peste
                  • Dec 2016
                  • 13661
                  • ROMANIA
                  This is not the correct bios... post the 32Mb bios...
                  • berrylinx
                    Workaholic
                    • May 2025
                    • 13
                    • Jamaica
                    Ok i uploaded this one after to the same post but didn't realize you responded before, I've re-uploaded here
                    • berrylinx
                      Workaholic
                      • May 2025
                      • 13
                      • Jamaica
                      Any body here able to help me with this please?
                      • volinakis
                        • Jan 2021
                        • 2874
                        • N/A
                        try
                        • berrylinx
                          Workaholic
                          • May 2025
                          • 13
                          • Jamaica
                          Originally posted by volinakis
                          try
                          doesn't work, machines doesn't even turn on, just an orange indicator light flashes when you press the power button, but no fan spin and no boot. i checked the bios and its seated perfectly
                          • volinakis
                            • Jan 2021
                            • 2874
                            • N/A
                            remove cmos battery and let it run for 2-3 minutes if you sure your chipset is proper soldered.
                            • berrylinx
                              Workaholic
                              • May 2025
                              • 13
                              • Jamaica
                              Tried that but still same issue, still no power
                              • volinakis
                                • Jan 2021
                                • 2874
                                • N/A
                                put back original bios, if laptop is not working it means you did a bad backup to your bios.
                                • berrylinx
                                  Workaholic
                                  • May 2025
                                  • 13
                                  • Jamaica
                                  Yes I assumed this was the issue and now I've overwritten the original, what can I do now to resolve this issue? I've tried writing back the original and experiencing the same issue. How can I get back a good bios for this unit now?
                                  • Markus1741
                                    • Sep 2020
                                    • 951
                                    • N/A
                                    Hello you can try this file maybe it helps ....
                                    • berrylinx
                                      Workaholic
                                      • May 2025
                                      • 13
                                      • Jamaica
                                      Hey just tested and same result, still no power other than orange indicator light when i press the power button
                                        DELL Latitude 7400 Notebook 7000 Specification for Upgrade or Repair
                                        This specification for the DELL Latitude 7400 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7400 boardview and 7400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7400...
                                        09-06-2024, 08:40 PM
                                        DELL Latitude 7400 Hybrid (2-in-1) 7000 Specification for Upgrade or Repair
                                        This specification for the DELL Latitude 7400 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7400 boardview and 7400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
                                        09-06-2024, 12:36 PM
