IP3_IN6_MB_V11_20200721A
  • jorgemfcardoso
    • Nov 2012
    • 5
    • braga
    Hello
    I need bios IP3_IN6_MB_V11_20200721A
    Insys wh1-140p
    No image, not process
    Power on no video
  • peste
    • 13924
    • ROMANIA
    Originally posted by jorgemfcardoso
    Hello
    Insys wh1-140p
    Power on no video
    post S/N, full name and model, motherboard model, etc.
    post the contents of the bios chip even if it is corrupted..
    • jorgemfcardoso
      • Nov 2012
      • 5
      • braga
      Model wh1-140p...
      sn:
      WH1140P012021
      • iZakre
        HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
        by iZakre
        Hello everybody!
        To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
        The thing is that I had installed TeamViewer and could log into the computer...
        02-19-2023, 02:27 PM
      • Focus2005
        HP OMEN 16-C0114NW – no image after replacing CPU Ryzen 7 5800H with 5 5600H and flashing BIOS
        by Focus2005
        Hello everyone.
        I have another HP OMEN 16-C0114NW laptop with serial number 5CD1501LJX. The original problem was as follows. The laptop could not load Windows and every time it threw a bluescreen - y - most often WHEA_UNCORRECTABLE_ERROR. The processor that was originally in it was AMD RYZEN 7 5800H MOBILE PROCESSOR - 100-000000295. I decided to replace it with a fully functional, used AMD RYZEN 5 5600H MOBILE PROCESSOR - 100-000000296, which I got from a donor board, on which it worked 100%. After soldering the processor, I also uploaded a new, fresh BIOS to it with the UBT2 program...
        05-01-2025, 05:41 AM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
        by Vesko356
        08-11-2023, 03:27 AM
      • grimacelord
        Latitude E6530 - Trouble Extracting BIOS Image From EXE
        by grimacelord
        Hi folks,
        I'm having a hard time extracting this Dell BIOS. I have a Dell Latitude E6530 that has BIOS corruption and I need to reflash with CH341A programmer. I have already taken dumps of both the 4MB and 8MB chips on the motherboard.
        Service tag number for this model is: "JYDWYW1".
        Link to latest BIOS for this Service Tag: https://dl.dell.com/FOLDER05371360M/1/E6530A22.exe
        I have tried:
        • Simply extracting with 7zip
        • PFSExtractor
        • Using "/writeromfile, /writehdrfile, and /writehexfile" commands
        • Check Temp folder
        10-26-2023, 08:15 AM
