Bios for Victus 16-e0800nc DAG3MPMBCE0
  • Sarurnluck
    • Aug 2025
    • Ukraine
    I have an HP Victus 16 laptop with motherboard DA0G3MPB6C0 REV:E (Ryzen 5 5600H, SPI chip Winbond W25Q128JW 1.8V).
    The laptop turns on (power LED and fans spin) but there is no display output.
    I already tried flashing the BIOS file from the official HP website, but it only contains the BIOS region and does not work when written directly to the SPI chip.
    I also tried Win+B recovery method with USB, but it does not start recovery.
    Could someone please share a full 16MB BIOS dump for this board (DA0G3MPB6C0) so I can flash it with programmer?
    Thank you in advance!
    • 22077
    Post the laptop serial number and the original bios backup
    • Sarurnluck
      • Aug 2025
      • Ukraine
      I don't have the original bios
      Serial number:5CD208MCJ6
        • 22077
        try this one
        • m1ch43lzm
          • Mar 2019
          • 1008
          • Peru
          It should work, AMD doesn't have ME or descriptor regions
          Try post 3 from here
          https://www.badcaps.net/forum/troubl...74#post1831374
          If it works, Go to position 326000h and overwrite "MPMLock" with FF FF FF FF FF FF FF, you want manufacturing mode to program S/N etc with HP BCU as you don't have backup to extract the DMI data from
          EDIT: Or the one above by SMDFlea
          http://ftp.ext.hp.com/pub/caps-softpaq/cmit/HP_BCU.html
          Code:
          Serial number 5CD208MCJ6
          SKU Number 50A34EA#BCM
          Build ID 21WW2TAT601#SBCM#DBCM
          Feature byte 3K6b7K7jaBapaqasawbhcbdUdXdpdqfPfdhZm9ncqt.h3
          Product name Victus by HP Laptop 16-e0xxx
          System Board CT number is on a sticker
          Feature byte and Build ID are also on a sticker inside the back cover
          Yes, product name is like that 16-e0xxx
          Change "Keyboard type" if you don't have a Right Ctrl key, set to New EMEA UK KB or something like that
          Win key will be lost...
          • Sarurnluck
            • Aug 2025
            • Ukraine
            Sorry, I forgot to write that I have a flash drive: w25q128jw 16mb 1.8V
            So the BIOS above won't work for me
            • m1ch43lzm
              • Mar 2019
              • 1008
              • Peru
              It's exactly 16777216 bytes, it should work...
              Code:
              16,777,216 088EB.bin
              • macabook
                by macabook
                🧩 Initial Issue
                07-24-2025, 02:17 PM
              • sssssssssssssss
                Need BIOS for HP Pavilion 15-n058sr recovery - Caps Lock blinking twice
                by sssssssssssssss
                I'm dealing with a classic BIOS corruption issue on an HP Pavilion 15-n058sr and hoping someone here might have the original BIOS file or point me in the right direction.
                Symptoms:
                • Laptop powers on but no display at all (completely black screen)
                • Caps Lock blinks twice with a pause, then repeats continuously
                • F12 LED stays on permanently
                • No POST, no boot sequence, nothing on screen
                Based on HP diagnostic codes, the 2-blink Caps Lock pattern indicates BIOS corruption/failure.
                What I've tried:
                • Hardware reset (battery removal, power
                09-04-2025, 06:45 AM
              • pirati
                by pirati
                10-27-2025, 04:20 PM
              • The_Memory_Guy
                Dell T7820 stuck in Bios Recovery Mode
                by The_Memory_Guy
                HI,
                I have a Dell T7820 stuck in Bios recovery mode. I never get Dell Boot screen or anything visible on screen. The system just gives me 3 white lights and 3 orange lights indicating Bios recovery mode.
                What I have tried to get to recover the Bios, there seems to be some conflicting advice about recovering the system.
                All of them say to download the latest bios from the dell website which is a .exe file. I have done that
                https://www.dell.com/support/product...BUT090/drivers
                Some...
                07-07-2025, 06:52 AM
              • mikinana64
                Fujitsu U939X BIOS Recovery (EC Corrupt)
                by mikinana64
                I was clean install Windows 10 Pro without installing driver, because i believe windows will download itself.
                But 2 days later it hard bricked, just battery LED charge indicator when plugged in, no boot or even post. Unplugging the battery will result zero response, LED flicker 0.1s and then everything turned off, no response to any button. Main BIOS powered 3.3V but EC is 0V.
                So i though it just BIOS corrupted, and confirmed EC BIOS has been corrupted (First header is 55 AA 01 00 FF FF FF and the rest is always FF FF until offset 10000 with 00 00 blank and 11000 where...
                10-23-2025, 02:13 AM
