DELL PRO 14 PC14250
  • Jm7016
    • Mar 2025
    • 9
    • Mexico
    DELL PRO 14 PC14250
    Good afternoon, could you help me unlock this laptop? Model: Dell Pro 14
    Service Tag: CFVDCB4
    Board Number: 243082-1
    It has two 256-bit BIOSes. I'm leaving the files. I hope you can help me. Thank you.
    Last edited by SMDFlea; 09-02-2025, 06:21 AM. Reason: added PC14250 to thread title
  • peste
    • 13588
    • ROMANIA
    post full name and model, etc.
    • Jm7016
      • Mar 2025
      • 9
      • Mexico
      Modelo: Dell Pro 14 Pc14250 Etiqueta de servicio: CFVDCB4.
      NĂºmero de placa: 243082-1 8FWYP$LA
      Sorry, that's fine.
      • Jm7016
        • Mar 2025
        • 9
        • Mexico
        Please can you help me, I already tried and I couldn't unlock it.
          • 21889
          is the suffix 8FC8 or something different
          • Jm7016
            • Mar 2025
            • 9
            • Mexico
            yes 8FC8
            • Jm7016
              • Mar 2025
              • 9
              • Mexico
              But the patch didn't work for me.
              • minhdigital
                • Nov 2022
                • 765
                • Vietnam
                Send to you, try !
                • Jm7016
                  • Mar 2025
                  • 9
                  • Mexico
                  Originally posted by minhdigital
                  Send to you, try !
                  Thank you very much my friend for your help but it is still blocked.
                  • dongspy06
                    • Dec 2023
                    • 26
                    • Phillippines
                    thank you in advance guys this is the exact model DELL PRO 14 PC14250 thats the exact model i upload the bios bin with password.. thanks in advance Kudos!
                      • 21889
                      Thread merged. Post the service tag .. read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
                      • dongspy06
                        • Dec 2023
                        • 26
                        • Phillippines
                        Model: Dell Pro 14 PC14250
                        Service Tag: HN7SGB4
                        Board Number: 233089-1
                        I hope you can help me remove the bios password. Thank you.
                        ill attach the below my bin file that back up that has a password thank you in advance
                        • gsm_code
                          • Oct 2023
                          • 53
                          • philippines
                          dell pro 14 pc14250 admin lock and need to remove custom logo can someone remove this first time encounter like this model need your help tnx.
                          serial: B85SGB4
                          8FC8
                          • gsm_code
                            • Oct 2023
                            • 53
                            • philippines
                            Anyone encounter with this model, its single bios chip, 00 FC AA and 00 FD AA was not found in this bin file,
                            need clean bios bin file tnx
                            • gsm_code
                              • Oct 2023
                              • 53
                              • philippines
                              serial: B85SGB4
                              8FC8
                              Need help wauting for solution like this model tnx.
                              • minhdigital
                                • Nov 2022
                                • 765
                                • Vietnam
                                Send to you, try !!
                                • gsm_code
                                  • Oct 2023
                                  • 53
                                  • philippines
                                  Send to you, try !!
                                  Admin lock not remove
                                  • minhdigital
                                    • Nov 2022
                                    • 765
                                    • Vietnam
                                    Again !
                                    • gsm_code
                                      • Oct 2023
                                      • 53
                                      • philippines
                                      Again !
                                      Brother keyboard light on but no display
                                      • gsm_code
                                        • Oct 2023
                                        • 53
                                        • philippines
                                        Send to you, try !!
                                        Custom logo remove but admin lock not remove
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • master3112
                                          by master3112
                                          07-29-2025, 01:55 PM
                                          Dell Thunderbolt Firmware
                                          by SMDFlea
                                          Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
                                          Some models have a choice of 2 different firmwares, it depends on the dell SKU.
                                          The SKU is in brackets (****)
                                          EDIT: NVM65...
                                          01-26-2025, 06:22 AM
                                        • F R 2568
                                          Dell Latitude 5420 does not start (no post) need help to find the reason why
                                          by F R 2568
                                          Hello all,
                                          this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                          I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                          If the laptop is only connected to the AC adapter (battery removed):
                                          When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                          The power/battery...
                                          01-08-2025, 05:45 AM
                                        • capoplays
                                          Help with BIOS update on Dell G15 5515 after chip replacement
                                          by capoplays
                                          Hey everyone,
                                          I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                                          The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                                          When I check the BIOS using the F12 menu Flash...
                                          10-24-2025, 06:53 AM
