MBPGM7TG8C-PP11
  • pokyss1
    • Mar 2019
    • 58
    • TUNISE
    MBPGM7TG8C-PP11
    hello ihave laptop cyberpower
    model number in bord
    MBPGM7TG8C-PP11
    mode :tracer edge 117e gm7tg7p
    dont have the original dump i have this dump bat not detect the ssd . you have solution for this.
    • 21679
    Please Type the laptop serial number, read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
    • pokyss1
      • Mar 2019
      • 58
      • TUNISE
      hell ihave this in the back
      GM7TG7P2213104918
      1829528-F5LYC8
        • 21679
        GM7TG7P2213104918
        1829528-F5LYC8
        try this bios.
        • Sean Devine
          Cyberpower 1285AVR (CP1285AVRLCD) reporting wrong battery voltage?
          by Sean Devine
          UPS turned off one night and it seemed that the 3 year old batteries gave out.
          Replaced with a new pair, but the UPS software claimed the battery voltage was only 18 volts and needed to charge. After 24 hours, the UPS claimed only 60% charge and 20 volts (although FWIW, my meter sees 27v).
          ...then I found various Cyberpower threads here with some guidance on what to check.
          C1 (22uF) tested at 2, so I replaced that.
          Put it all back together and didn't see a change on the reported battery voltage. Although, I did run the quick battery diagnostic...
          03-03-2025, 08:23 PM
        • KLINIK ELEKTRONIK
          AFTERSHOCK VAPOR 17X GM7TG7P
          by KLINIK ELEKTRONIK
          BIOS NORMAL BACKUP
          CODE BOARD : GM7TGxP MB V.10...
          08-02-2025, 01:18 AM
        • quickname
          Cyberpower 1500AVR UPS repair
          by quickname
          I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
          I decided to verify that the batteries were...
          11-12-2023, 09:57 AM
        • pete_c
          CyberPower 1350AVR and 1500AVR - Repair
          by pete_c
          Both are older than years old now.
          Pooling info here from what I have read.
          Cyberpower 1500AVR takes 4-5 days to charge batteries after test depletion.
          Made an RPi Nutserver for the rack and using PFSense for the telco area with an APC.
          Using Nutserver with Home Assistant.
          Last week ordered
          33uF 200v Rubycon Electrolytic Radial Lead Capacitors
          22UF 50V Electrolytic Radial Lead Capacitors
          VIPer22A "Original" ST 8P DIP IC 2 pcs
          Noticed that the old Cyberpower UPS's output...
          05-06-2022, 04:10 PM
        • timakaze
          CyberPower Smart-UPS OL2000ERTXL2U not charging.
          by timakaze
          So i have this UPS Cyberpower OL2000ERTXL2U that is no longer charging the batteries and i would like to try and figure out if its fixable ? It did throw up and error message on the LCD saying Charger Failure and so i powered it off and back on again and it no longer shows the error and seemed to be fine. But the batteries just go flat now and it dose not show any errors other than batteries low.
          Have taken some pictures but i dont know where the charging circuit is or what parts to look out for to replace. Everything looks good. No swollen or leaking caps. No burnt or discolored...
          09-28-2024, 05:28 PM
