hp da0p9mb36a0 rev a bios lock
  • Peperoni23
    • Oct 2016
    • 27
    • Philippines
    HP stream-14-cb172wm
    product number 9VK98UA
    main motherboard - DA0P9MB36A0 REV A
    Problem bios lock
    please unlock thanks all masters
  • peste
    • 13924
    • ROMANIA
    Problem bios lock
    sure this is the original bios of the laptop...check it again...post the S/N too...
    • Peperoni23
      • Oct 2016
      • 27
      • Philippines
      [QUOTE=Peperoni23;n3664774]HP stream-14-cb172wm
      serial number -5cd201ktpm
      Problem bios lock
      • peste
        • 13924
        • ROMANIA
        [QUOTE=Peperoni23;n3664874]
        Problem bios lock
        bios extracted from HP site update for HP Stream - 14-cb172wm
        DMI 3C7000 - 3CAFFF
        KEYWIN 3C5000 - 3C503F
        • cr4zychriss
          by cr4zychriss
          • Rebrand: PC Specialist
          11-14-2025, 04:04 PM
        • sssssssssssssss
          Need BIOS for HP Pavilion 15-n058sr recovery - Caps Lock blinking twice
          by sssssssssssssss
          I'm dealing with a classic BIOS corruption issue on an HP Pavilion 15-n058sr and hoping someone here might have the original BIOS file or point me in the right direction.
          Symptoms:
          • Laptop powers on but no display at all (completely black screen)
          • Caps Lock blinks twice with a pause, then repeats continuously
          • F12 LED stays on permanently
          • No POST, no boot sequence, nothing on screen
          Based on HP diagnostic codes, the 2-blink Caps Lock pattern indicates BIOS corruption/failure.
          What I've tried:
          • Hardware reset (battery removal, power
          09-04-2025, 06:45 AM
        • haitham sharabati
          by haitham sharabati
          Hello engineers 😀,
          🔧 Device Info:
          - Model: HP 15-da2007ne
          - Product Number: 8XF55EA#ABV
          - Serial Number: CND0338P0D
          - CPU: Intel Celeron N4000
          💀 Problem:😅
          08-07-2025, 04:54 AM
        • ArtMov
          [HELP] Asus g732lv ami bios overclocking lock reseting after reboot
          by ArtMov
          Hi guys, i have a problem , my bios resets disabled overclocking lock setting to enable after reboot, please tell me which function can be responsible for restoring the stock config for this option, loading parameters from nvram and so on, like bios ,protection, from asus. My bios made me angry) Set default parameter to disable in amibcp 5 , doesn't help(
          1. I made overclocking lock disabled the default in amibcp
          2. I changed the varoffset to the wrong one, but it led to the programmer, it was very tedious and nervous, I really regretted it, my chip is on the back of the...
          03-31-2023, 01:30 PM
        • Akhlz001
          by Akhlz001
          09-20-2025, 07:15 PM
