Yoga Slim 6 14IRH8 - Type 83E0 bios
Try
Attached Filesif you find these attachements useful please consider making a small donation to the site
Thanks for the archive. I already have that file - I downloaded the BIOS for Windows from Lenovo’s website, opened it with WinRAR, and extracted the same file.
Unfortunately, with your archive, it didn’t work. I held down Fn+R, turned on the laptop, and after a loud beep released the keys. The laptop kept beeping loudly for about a minute, then restarted and brought me back to the same menu with two options - none of which work....
Would you happen to have an older version of the BIOS? Not the one currently available on Lenovo’s official site?
UPD: I also noticed that new log files were created on the USB stick... attached in the archive.
Here is the new file.
use a recorder.Attached Filesif you find these attachements useful please consider making a small donation to the site
Hello, I have the same laptop. Yoga Slim 6 14IRH8. S/N: YX09V3WX, motherboard MBH83E0 I513500H UMA16G, p/n: 5B21L52211. Initially, it wouldn't turn on after a Microsoft update. The customer took it to several service centers. Now one of the flash drives on the board is empty. I created a dump of 25Q128 and 25Q64 from the official Lenovo website, but 25Q80 is empty and I don't know what should be there. Thanks in advance for any help or direction. I'm attaching two existing dumps, as well as two created ones.Attached Filesif you find these attachements useful please consider making a small donation to the site
25Q80 probably PD/Thunderbolt firmware. Can you see which IC it is connected toHello, I have the same laptop. Yoga Slim 6 14IRH8. S/N: YX09V3WX, motherboard MBH83E0 I513500H UMA16G, p/n: 5B21L52211. Initially, it wouldn't turn on after a Microsoft update. The customer took it to several service centers. Now one of the flash drives on the board is empty. I created a dump of 25Q128 and 25Q64 from the official Lenovo website, but 25Q80 is empty and I don't know what should be there. Thanks in advance for any help or direction. I'm attaching two existing dumps, as well as two created ones.Comment
Good afternoon. Unfortunately, I couldn't find where the data lines go from the 25Q80 chip. However, I found a dump of this chip at a previous service center. However, this dump also doesn't initialize. Could someone help me check the BIOS integrity? Or could compile the dumps based on mine? Thank you in advance.Attached Filesif you find these attachements useful please consider making a small donation to the site
bios version N1CN15WW attached. Can`t find the 25Q80 firmware.Attached Filesif you find these attachements useful please consider making a small donation to the site
Hey folks I've got a client here with the same issue of the "Do you want to recovery ROM part". Never seen this before. Attached is a dump of both the 128Mbit and 64Mbit chips as they are. I have a 3.3v programmer so can flash binaries manually unless there's some easier way (I've seen several people mentioning using a USB but I have no idea how).
Yoga Slim 6 14IRH8
MTM: 83E00015IN
S/N: YX07N0Y0
MO: YXN0B3815006
Mfg Date: 2023/08/15Attached Filesif you find these attachements useful please consider making a small donation to the site
Try flashing only 16MB (128) BIOS with your DMI inserted, used post 11 as base
BIOS ver N1CN15WW
S/N YX07N0Y0
DMI 1D9000-1DAFFF on 16MB chip
8MB (64) chip contains ME region, if it boots fine afterwards leave as isAttached Filesif you find these attachements useful please consider making a small donation to the site
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
by beogeekI've currently got a Lenovo Yoga Slim 7 14APU8 that is not posting. Its fan spins, the keyboard lights up, and the caps lock doesn't work. It was taken to some shop for cleaning, and then they updated or tried to update the bios. After that, there was no display and no post. I've removed the bios ic from the board and made a bios dump. I need some assistance going forward, as I suspect this is probably just a bad bios issue. I've tried searching for a dump, but no luck; if anyone can throw me a bone, it would be much appreciated!
Attached is the bios dump in the state I received it...-
by pavel.kincHello everyone, I would like to have the bios file for this laptop please. After the bios update it stopped working, only a black screen.
Lenovo Yoga Slim 7 Pro 14ACH5 , S/N:PF3DGGVN, motherboard HS45H NM-D691 Rev:1.0
There is no working file. Thanks for any help....-
by macabookHello everyone,
07-24-2025, 02:17 PM -
by rushouse77Hello! i need cleam bios dump for Yoga slim 6 14APU8
Does anyone have or can help correct my dump? There is absolutely nothing on the Internet about this model...
MTM: 82X3000NRK
Board: NB6287C_MB_V5
Here is my original bios with pass:...-
- Loading...
