HP Laptop has firmware lock, I have tried flashing new bios from HP website hope that would be it. When trying to install windows 11 it would not see the Nvme in windows 11 installation but see it in the bios and diagnostics test. I get 0XFFEE016 when trying to use HP Recovery Tool on USB I realize theres no info on the hp in the bios like missing SN# after flashing from HP website. I have original F.32 backup thats older bios and I also tried to update bios to F.39 with USB but was still locked, both files in attachements SN#5CD143C3QM ProductID# 544Q7UA#ABA
HP Laptop 15-dy2039nr (544Q7UA) Need Help
This topic has been answered.
Answer selected by iKevin at 05-27-2025, 09:34 AM.
HP Laptop has firmware lock, I have tried flashing new bios from HP website hope that would be it. When trying to install windows 11 it would not see the Nvme in windows 11 installation but see it in the bios and diagnostics test. I get 0XFFEE016 when trying to use HP Recovery Tool on USB I realize theres no info on the hp in the bios like missing SN# after flashing from HP website. I have original F.32 backup thats older bios and I also tried to update bios to F.39 with USB but was still locked, both files in attachements SN#5CD143C3QM ProductID# 544Q7UA#ABAAttached Files- Selected Answer
by BloodhoundjeHi everyone,
I have desoldered the bios chip (GigaDevice...-
Channel: BIOS Requests ONLY!
by JDongThere was an error... Aborting......I'm using another Linux Laptop with Zorin OS...to try and patch my Lenovo V15 G4 IRU with above specs....It originally had Windows 10/11 installed and converted to a dual boot Kali OS/Parrot OS system. I may have used the wrong lenovo_autopatcher_0.2 (I believe was posted by @knucklegrumble....I am out of ideas and flat broke so i cannot afford another fix (spent it all as an e-com entrepreneur does) any help from anyone would be GREATLY appreciated.....
- Laptop Model: Lenovo V15 G4 IRU
- Issue: Forgotten supervisor password.
- BIOS Chip: GD25B128E (or GD25B128B
by AquaMan UaHello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...2 Photos
by kenkaniffProduct Name: HP Pro x360 Fortis 11-inch G9
System BIOS: U94 Ver.01.08.00 10/06/2023
Serial Number: 5CG31946F5
SKU Number: 85W05EC#AK8
Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
I needed to remove bios password...-
by Loli PopuHello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
- Loading...
