ThinkBook 16 G4+ IAP Laptop - Type 21CY
  • d0gan
    • Feb 2020
    • 7
    • Denmark
    Hope somebody can help with this: ThinkBook 16 G4+ IAP Laptop - Type 21CY
    power button lights up, keyboard backlight comes on, the fans are spinning. However no video on the screen. Tried with new LCD-panel but no luck. I assume the bios is corrupted on this computer.
    Could someone, please provide a clean/updated bios bin for this computer? I attached the original bin file here. Thank you.
    Serial# YX07Z1B3​
  • peste
    • 13421
    • ROMANIA
    Serial# YX07Z1B3
    bios extracted from the update site Lenovo penyru BIOS Update for ThinkBook 14 G4+ IAP, ThinkBook 16 G4+ IAP
    DMI 375000 - 376000
    • masterluo
      • May 2025
      • CN
      Hey bro, I meet the same problem, what is the bios ship on this laptop? "Winbond 25R64JVSIQ" ship or "XMC 25QH128CHIQ" ship? Thank u
      • titanium7
        • Jan 2011
        • 11
        Hello
        I'm looking for a clean BIOS file for my Thinkbook 16 G4 +IAP S/N: YX07BNG5
        I forgot my supervisor password (BIOS)
        Here is my original file
        25r64.zip
        • peste
          • 13421
          • ROMANIA
          Originally posted by titanium7
          Hello
          25r64.zip
          post S/N, full name and model, motherboard model, TYPE,etc.
          • hardware1
            • Sep 2021
            • 2946
            • N/A
            Hello
            25r64.zip
            Write what peste asked you for. Also look for another 16MB chip on the motherboard and upload its file.
            all donations are welcome,
            • titanium7
              • Jan 2011
              • 11
              S/N, full name and model It's in my post.
              MTM:21CY0076GE
              MO:YXN0B3715011
              Where can I find the motherboard number?
              There is still a chip 25Q80 with this content installed
              25q80.zip
              • hardware1
                • Sep 2021
                • 2946
                • N/A
                MTM:21CY0076GE
                MO:YXN0B3715011
                25q80.zip
                This 1MB chip is for Thunderbolt Firmware, solder it back and search for another 16MB chip (128Mbit), it could be in SOIC8 or WSON8 package.
                • titanium7
                  • Jan 2011
                  • 11
                  I found it:
                  Winbond 25Q128JVSQ
                  Here's the file (read from the board)
                  Verify is OK
                  • hardware1
                    • Sep 2021
                    • 2946
                    • N/A
                    I found it:
                    Winbond 25Q128JVSQ
                    Verify is OK
                    This BIOS will erase your Password. You have to flash both files (16MB+8MB) and just solder back the 1MB chip.
                    • titanium7
                      • Jan 2011
                      • 11
                      Can I program the chips in the board?
                      • titanium7
                        • Jan 2011
                        • 11
                        Both chips programmed externally.
                        Verification was OK.
                        Notebook won't start. LED only lights up briefly.
                        • titanium7
                          • Jan 2011
                          • 11
                          just solder back the 1MB chip. ??
                          • hardware1
                            • Sep 2021
                            • 2946
                            • N/A
                            Yes, just solder the 1MB chip back don't erase it.
                            It's better to flash the chips outside the motherboard and choose verify after programming them.
                            • titanium7
                              • Jan 2011
                              • 11
                              I didn't do anything with the 1 MB chip and soldered it back on after you said it had nothing to do with the BIOS. I flashed both of your files.
                              When I turn it on, the LED lights up for about 5 seconds and then goes out again.
                              After that, it lights up several more times for a few seconds, then everything goes off again.
                              The fans are constantly off.
                              Before flashing, the notebook started normally with Windows 11,​
                              • hardware1
                                • Sep 2021
                                • 2946
                                • N/A
                                You can flash back your original BIOS (16MB+8MB) and see if it's will work or not.
                                • titanium7
                                  • Jan 2011
                                  • 11
                                  that doesn't work anymore
                                  • hardware1
                                    • Sep 2021
                                    • 2946
                                    • N/A
                                    So there is something wrong happened to the device. Let us know which SPI Programmer do you use? Are you using a clip/clamp or de-solder the chips from the motherboard? Do you choose verify after programing the chips and it pass successful? What is the full number of both chips? If you can send a close and clear image to your chips on the motherboard will be good. Finally what is the motherboard number?
                                    • titanium7
                                      • Jan 2011
                                      • 11
                                      I use a CH341A programmer.
                                      Chips were programmed externally using Neoprogrammer and ASPROG.
                                      Verification was OK every time.
                                      Chips are:
                                      Winbond 25Q128JVSQ
                                      Gigadevice 25R64CSIG
                                      Mainboard number: 5B21H68229
                                      • hardware1
                                        • Sep 2021
                                        • 2946
                                        • N/A
                                        Chips are:
                                        Winbond 25Q128JVSQ
                                        Just for your information, your laptop should works fine on the files that I sent or using your original backup. Everything looks fine according to the information you gave, but perhaps you rotated the chips, swapped them with each other, the chips got damaged or you moved a tiny component from the motherboard by accident.
                                        • DbLen
                                          ThinkBook 14p G2 ACH Laptop - Type 20YN BIOS password unlock
                                          by DbLen
                                          Hi, I was hoping osmeone could help me with this.
                                          I have a Lenovo Thinkbook G2 I bought on ebay and I was hoping to enable vrtualization to run WSL but there is a BIOS password lock on it.
                                          The serial number is PF37TGLV and the MTM is 20YN0000CD. I downloaded and backed up the BIOS using Universal BIOS Backup Toolkit 2.0
                                          I have attached a copy here:
                                          Please let me know if anything else is needed....
                                          10-07-2024, 03:03 PM
                                          Lenovo ThinkBook ThinkBook 14s Yoga ITL Notebook Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkBook ThinkBook 14s Yoga ITL Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkBook 14s Yoga ITL boardview and ThinkBook 14s Yoga ITL schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 04:10 AM
                                        • RdeveLabs
                                          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                          by RdeveLabs
                                          To all the members here...
                                          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                          05-05-2025, 04:59 AM
                                          Lenovo ThinkBook 13s-IML Ci5 16/512 13.3IN W10P Notebook Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkBook 13s-IML Ci5 16/512 13.3IN W10P Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkBook 13s-IML Ci5 16/512 13.3IN W10P boardview and ThinkBook 13s-IML Ci5 16/512 13.3IN W10P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-06-2024, 02:24 PM
