Acer A515-57 bios damage
  • the Benninger
    • Nov 2022
    • 189
    • venezulan
    Hi Folks This machine does not turn on, when you press the power bonton, the blue side LED lights up for a second then it turns off and does nothing else, the fans do not turn, I already ruled out that it was a RAM or SSD memory problem, I want to try to edit the BIOS is 32mb, I don't know the hex address to find and copy the DMI
    If someone wants to collaborate, these are the data and the BIOS that they download from the support
    Model A515-57 5588
    S/N:NXKNFAL001447007DC9X00
    SNiD: 447002012935
    MoBo:HH5A4 LA-M211P Rev 1A
    QRcode: GA:OLLG 44202F68
    ​I would have no problem making the edit if you indicate the addresses, thank you very much
    • 22279
    NXKNFAL001447007DC9Z00 ,search for the serial number with your hex editor, the first 4 or 5 digits will be enough for a text search.
    1068000 - 1069FFF and 1117000 - 111703F
    For the win key search with software, or with hex pattern 01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 1D 00 00 00
    • Pccare01
      • Jun 2023
      • backkok
      ol
      • EbrahimSiami
        Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
        by EbrahimSiami
        I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
        **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
        **What I have tried so far:**
        1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
        07-02-2025, 02:31 PM
      • Wg188
        ACER Veriton Z4660G AIO bios help
        by Wg188
        I have an Acer veriton Z4660G all in one pc,
        Model: Z4660G-I5850H1 (VZ4660G_W)
        Need bios dump and schematic would save my life !
        to make a long story short I bought this all in one used
        with a broken lcd, with the objective of making a custom desktop out of it
        ,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...
        06-17-2023, 02:20 PM
      • macabook
        by macabook
        🧩 Initial Issue
        07-24-2025, 02:17 PM
      • James194zt
        Acer Nitro 50-640E Corrupted BIOS Dump
        by James194zt
        My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
        All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...
        04-28-2025, 03:29 PM
      • cr4zychriss
        by cr4zychriss
        • Rebrand: PC Specialist
        11-14-2025, 04:04 PM
