HP Omen 17-cb0140ng (I7 9 Gen, RTX 6GB, LA-H462P) BIOS
  • Tcoh
    • Apr 2020
    • 7
    • Deutschland
    I have an issue with this laptop. The original BIOS was already overwritten and was not saved before, so I don't have a dump or know which BIOS has to be flashed on this Device. In the HP image for this model, there are four different Versions:
    With two of those (08600, don't know without testing which is the second) the Laptop turns on, but no Display (also not on HDMI) and also no capslock (except if i remove the RAM Module, it blinks 3 times). Power Consumption is around 60W (Powersupply measured at the socket). With the other two, it turns on and Capslock blinks 5 long and 3 short, it also only consumes around 30W.
    Can anyone tell me which of those BIOS is right? And what Data has to be added to the BIOS?
    • 21679
    Please read the rules and post the laptop serial number https://www.badcaps.net/forum/troubl...before-posting
    • Tcoh
      • Apr 2020
      • 7
      • Deutschland
      SN: CND9354XQ5
      • peste
        • 13421
        • ROMANIA
        Originally posted by Tcoh
        SN: CND9354XQ5
        if you don't have the original bios you can just try them one by one...if it doesn't work either you write the bios with errors.. or the laptop has another problem..
        The bios chip must be unsoldered from the board before writing or reading..
        do not use the clip, you may have errors..if you do not have anything to unsolder it with,
        solder wires between the programmer and the bios chip..
        • Tcoh
          • Apr 2020
          • 7
          • Deutschland
          There is no way to find out, which could belong to the Laptop? The thing is, it's hard to search for the problem of the laptop, if there a different results with different BIOS (either 5+3 blinks, or no blinks).
          I don't have e clip, they never worked for me. I flashed with wires and also flashed the unsoldered chip.
          • JoWed
            Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
            by JoWed
            Hello Community,
            I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
            07-01-2025, 09:32 AM
          • Dani Rahal
            hp omen 17-cb0247ng bios
            by Dani Rahal
            Hi can some one help me plz
            i have hp omen 17-cb0247ng (la h492p) it have bios problems and i flashed bios from usb the new one v53 and its boosting to bios but did not start to windows (blue screen of death) i tryed evry thig and not working
            i flashed bios with programer ( CH341A )and it will not boost to bios just fan working no disply now i flash the orginal bios back its working but no booting to windows same problem
            the bios from hp after extract have 4 bios file same size i tryed 4 of them not working
            i have the orginal bios if some one can see what the problem or...
            05-30-2025, 09:11 AM
          • macabook
            by macabook
            🧩 Initial Issue
            07-24-2025, 02:17 PM
          • zerbatin
            HP Omen 16-c0825no BIOS.
            by zerbatin
            I have problem with my laptop. When I turn it on it do not POST. Black screen with FAN not working, When pressing CTRL+V/B I can go into BIOS update, but after auto restart there is no update screen. Nothing happen.
            I have tried using this DUMP but with no go,
            https://www.badcaps.net/forum/troubl...os#post3210916
            My winbond BIOS chip got fried as well after 4th attempt, now it is unsoldered and I am waiting for...
            07-17-2025, 02:14 PM
          • MDSI
            HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
            by MDSI
            I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
            Details:
            Model : HP OMEN 17-an012nf
            Motherboard Part Number : DAG3BAMBAF0 REV : F
            Serial Number (S/N) : 5CD7280D51
            BIOS chip : Winbond W25Q64VSIQ
            Programmer : EZP2023+
            Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
            I already...
            07-28-2025, 07:11 AM
