no tpm after pch replacement on asus g532lws board
  • bios29
    • Dec 2018
    • 20
    • france
    Hello ,
    I replaced a pch on an asus g532lws laptop board , all is working fine , but when i want to upgrade to windows 11 tpm 2.0 is no available , i search on google , found somethings who speak about intel ptt , someone know how to reprogram or reset the tpm feature?
    i have a backup bin of the bios if something need to be modified into bios , maybe something exist like for the intel me region?.
    thanks a lot for you answer
    serial of the machine is L6NRKD010738235
    • 20860
    post your backup, and type the laptop serial number as per the rules -> https://www.badcaps.net/forum/troubl...before-posting
    • bios29
      • Dec 2018
      • 20
      • france
      its done bios posted + serial
        • 20860
        Clean bios.
        • bios29
          • Dec 2018
          • 20
          • france
          You Fix the bios ?you can explain a Little what you’ve done?thank you
            • 20860
            I cleaned the ME firmware, that`s all it needed. Whenever you change a PCH clean the ME firmware.
            • bios29
              • Dec 2018
              • 20
              • france
              Same issue when i try to install Windows 11 says no tpm found, so when the pch is replaced, impossible to get tpm 2.0?
                • 20860
                Go into the advanced bios settings, then security. Find Intel PTT and set it to enable. https://www.asus.com/support/faq/1046215/
                • bios29
                  • Dec 2018
                  • 20
                  • france
                  Nothing about tpm in bios , maybe ita because i used a pch from a other board ?need to be a new pch to get tpm ?i found nothing on internet about that issue
                  • DynaxSC
                    ASUS STRIX Z490-F GAMING - No POST, stubborn board
                    by DynaxSC
                    I have this very stubborn ASUS mobo on the bench, and I already face the wall with it. It just refuses to POST, although everything seems to be OK.
                    The situation looks like this:
                    After connecting the board to the power supply on Nuvoton (SLP_S3#, pin 64), the Low signal (50 ohm resistance) appears immediately. PWRNTN# signal goes through Nuvoton to the chipset (confirmed after removing the chipset). The following conditions are then met for the chipset to generate the SLP_S3# signal:
                    1. RTC oscillates normally (32.768KHz).
                    07-08-2022, 05:45 AM
                  • ShadowAi12
                    ASUS ROG STRIX B550-F GAMING — Board not powering on properly
                    by ShadowAi12
                    I recently bought an ASUS ROG STRIX B550-F GAMING motherboard that was listed as "dead, not powering on." However, it does show some signs of life. I've performed several basic measurements and would like to share the results.
                    • The board enters a "ready to power on" state after plugging in the PSU.
                    • Pressing the power button increases power draw.
                    • Sometimes, touching the RSMRST_L pad with a multimeter probe causes the board to shut off and return to standby.
                    Measurements:
                    (taken after pressing the power button, while the board is attempting to start)
                    • H_SKTOOC#
                    06-11-2025, 01:05 PM
                  • boosti45
                    Macbook pro logic board replacement parts quesion
                    by boosti45
                    i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                    08-21-2024, 05:23 AM
                  • jimbodriver
                    Faulty ASUS X99-PRO board. Some progress with repair. Need advice\help please.
                    by jimbodriver
                    I am trying to learn electronics repair. I purchased a “faulty for spares/repairs” ASUS X99-PRO/ USB 3.1 motherboard for a very low price from ebay – a good enough price to offset the high probability that the board was completely toast and not realistically repairable.
                    Initial results:
                    Board would power-cycle when turned on either with switch on board or shorting pwr pins. Fan would spin for a second or so and a QCODE of 00 would display then it would power off and then do the same thing again over and over. I think maybe 2 times in about 100 attempts...
                    03-20-2022, 02:30 PM
