HP ZBook Power 16 inch G11 bios password
  • keczuk
    • Dec 2019
    • 84
    • WWW
    Some one can make patch for unlock bios password for:
    SerialNumber:5CD4441BPV
    ProductConfigurationID:9A668AV
    Board CT Number:PTYAV028JK600K
    ProductName:HP ZBook Power 16 inch G11 Mobile Workstation PC
  • tuyen821991
    • Oct 2024
    • 50
    • Viet Nam
    try flash only Bios
    1st boot reset factory default
    build ID 24WWL1BZ601#SAK8#DAK8
    Feature Byte 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbhcAfPguhKhkj4jhk8mEn7nVpDpVpnpqprqDqzr4rNrPrbs4.Yf​
    • keczuk
      • Dec 2019
      • 84
      • WWW
      Originally posted by tuyen821991
      try flash only Bios
      Not working. Show me enter power on password or administrator password.
      He also not turn in manufactured mode.
        • 21926
        As far as i know there is currently no way to patch a G11 bios
        • keczuk
          • Dec 2019
          • 84
          • WWW
          I was make one patch and he turn on on manufactured mode, but Factory default was not working, password option stil show me (enter old password) if i want change to empty.
          • volinakis
            • Jan 2021
            • 2874
            • N/A
            please post the patch entering in mpm mode.
            • keczuk
              • Dec 2019
              • 84
              • WWW
              here is mpm mode patch
              • Stefan Steff
                • Mar 2024
                • 361
                • Romania
                Probably something like this...
                keczuk you are free to try this patched bios file...
                I never had a G11 on my bench but it worth at least one try...
                • volinakis
                  • Jan 2021
                  • 2874
                  • N/A
                  thank you. Please try this file and at 1st boot go in bios setup -main - reset to factory settings and let me know if it works.
                  • keczuk
                    • Dec 2019
                    • 84
                    • WWW
                    Both bios works same like my patch, so manufactured is turn on, apply factory default not working, he turn again, and in bios when i press change password he want old password, in security tab when i press restore security setting to factory, he want admin bios password.
                    • volinakis
                      • Jan 2021
                      • 2874
                      • N/A
                      ok, thanks for feedback
                      • Stefan Steff
                        • Mar 2024
                        • 361
                        • Romania
                        Thanks for feedback!
                        • keczuk
                          • Dec 2019
                          • 84
                          • WWW
                          No idea for this model ?
                          • keczuk
                            • Dec 2019
                            • 84
                            • WWW
                            still no solution?
                            • keczuk
                              • Dec 2019
                              • 84
                              • WWW
                              still no solution hmmm ??
                              • Bios Cracker
                                • Oct 2024
                                • 322
                                • India
                                Post what issue you are facing??
                                • Stefan Steff
                                  • Mar 2024
                                  • 361
                                  • Romania
                                  Let's try again 2 variants...post feedback.
                                  • keczuk
                                    • Dec 2019
                                    • 84
                                    • WWW
                                    Both case are same. Im enter in manufactured, i can go to bios but if reset default in main tab, he don't reset password. In security tab i have change bios password but i need enter old password, if i want use security reset option i need enter old password. Any idea ? where this is stored now ?
                                    • Stefan Steff
                                      • Mar 2024
                                      • 361
                                      • Romania
                                      What do you mean by "...Im enter in manufactured..."?
                                      You fill all missing tags with BCU ?...and after that you enter the BIOS and the password is still present?
                                      So, I'm doing like this and every time it's functioning fine...(probably until G11...) after writing the patched content I have a live Windows 11 with BCU and save the config in to the BIOS.
                                      At restart there are cases when asking if the data is right or not and after confirming all works perfect... in the other cases just boots fine w/o password.
                                      • keczuk
                                        • Dec 2019
                                        • 84
                                        • WWW
                                        What do you mean by "...Im enter in manufactured..."? ->> LIKE I Was write, I can go to bios, but if reset default in main tab, he don't reset password. In security tab i have change bios password but i need enter old password, if i want use security reset option i need enter old password.
                                        MANUFACTURE mode = board is in manufactured state, have read text in left top corner.
                                        NEVERMAIN i was make XX patch file and i was find solution for G11 laptops.
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                          HP ZBook Power ZBook Power 15.6 inch G9 Mobile Workstation PC Mobile workstation Specification for Upgrade or Repair
                                          This specification for the HP ZBook Power ZBook Power 15.6 inch G9 Mobile Workstation PC Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook Power 15.6 inch G9 Mobile Workstation PC boardview and ZBook Power 15.6 inch G9 Mobile Workstation PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                                          09-07-2024, 05:20 AM
