HP ProBook 635 Aero G8 - power on with only 0.02A - fix empty BIOS please
  • bajdik
    • Aug 2015
    • 68
    • Czech Republic
    Laptop powering with only 0.02A load.
    No short circuit found, so I try to read BIOS.
    It looks very "empty", isn't it?
    Can anyone check it, please?
    This is my dump from CH341A.
    Model: HP ProBook 635 AERO G8, S/N: 5CG1342VLN, ID: 43A50EA#BCM
    Thank you for your time.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12423
    Reread the chip, CH341A sometimes gives incorrect results.
    • bajdik
      • Aug 2015
      • 68
      • Czech Republic
      I tried it several time. I didn't find any working DUMP for this model. I would like to try flash another file.
        • 22170
        look on the board for another 32MB bios and post it
        • hoaca388
          Badcaps
          • Jan 2022
          • 12423
          Where to dig new file when there is no original file.
            • 22170
            Virgin bios.
            • bajdik
              • Aug 2015
              • 68
              • Czech Republic
              Just for information - I did not find there is a two pieces of 256 mbit SPI FLASH, sorry. When I put heat on the bottom BIOS chip, laptop start.. So, it was really a BIOS problem, but the CHIP itself.
              • studdy05
                Bricked HP Probook 450 G7 Bios questions
                by studdy05
                Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                Ive got...
                07-08-2025, 09:24 PM
              • macabook
                by macabook
                🧩 Initial Issue
                07-24-2025, 02:17 PM
              • cr4zychriss
                by cr4zychriss
                • Rebrand: PC Specialist
                11-14-2025, 04:04 PM
              • angrej4953
                HP ProBook 635 Aero G8 bios
                by angrej4953
                helo sir pleas fix my hp 845-g8 no display
                other bios display ok but endpoint error
                SRno. 5CG13449V4
                MOD EDIT: Model 635 Aero G8...
                04-12-2025, 03:24 AM
              • Kokopolokoks
                HP Elitebook 840 Aero G8 Bios
                by Kokopolokoks
                Hi good day guys i have a HP Elitebook 840 Aero G8 that has corrupted bios can someone help me fix it. Here is the Main and the EC Dump. Thank you in advance
                HP EliteBook 840 Aero G8
                SN: 5CG1282LHJ
                ProdID 3D0G0AW...
                10-14-2025, 12:34 AM
