HP ProBook 635 Aero G8 bios
  • angrej4953
    • Aug 2021
    • 21
    • india
    helo sir pleas fix my hp 845-g8 no display
    other bios display ok but endpoint error
    SRno. 5CG13449V4
    MOD EDIT: Model 635 Aero G8
  • hoaca388
    Badcaps
    • Jan 2022
    • 11736
    SRno. 5CG13449V4
    HP ProBook 635 Aero G8 Notebook PC (4Q1T0PA)
    CPU side
    • angrej4953
      • Aug 2021
      • 21
      • india
      CPU side
      THANKS SIR WORKING
        SMDFlea commented
        Editing a comment
        Posts moved to new thread topic,
    • wahoo28
      • Apr 2025
      Many thanks in advance for any help!
      Motherboard: LANCIA13/Grizzly2.0-6050A3234201-MB-A01 (A1)
      HP ProBook 635 Aero G8 (43A03EA#ABU)
      S/N 5CG1345RXQ
      Salvage laptop with lots of external damage, powered on OK but BIOS-locked.
      I desoldered the back chip (a Winbond 25Q256JVEN) and read it twice using a CH341A programmer (same read).
      Attempted to do the ActiveNvramRegn clear (there were three or four instances) and programmed on a brand new 25Q256JVEN left from another project (see below).
      I was not expecting so many instances of ActiveNvramRegn, I salvaged a very similar 635 Aero G7 in the same way (same front/back chips, similar MB with earlier generation processor) and it only had one instance of ActiveNvramRegn, and the cleared file did unlock the BIOS and recovered it perfectly.
      Re-soldered the chip two or three times as no power-on initially (bad contacts, I'm a newbie...), eventually powered on but with endpoint security controller issue and screen flashing, with laptop unresponsive (keyboard inputs not recognised) while screen is off.
      It is not a screen issue - I forced HDMI output by unplugging the onboard screen and it is the same thing.
      Tried desoldering again, re-programmed the original "locked" file and re-soldered but it has not solved either issue (still having endpoint security and screen flashing).
      At this point I don't know if it is a BIOS/EC programming problem or if any other hardware bits have failed - closer inspection revealed some corrosion/possible liquid damage across the board contacts, which I removed with isopropyl and a brush - however, it was powering on fine with all this corrosion before removing the back chip so I don't know...
      Also tried using RCUnlocker but it requests a 16mb chip (this motherboard, as far as I can see, only has two 32mb chips front and back exactly like the 635 Aero G7 I salvaged earlier).
      Attached are the original files, I detached and read the front BIOS too this time.
      • hoaca388
        Badcaps
        • Jan 2022
        • 11736
        S/N 5CG1345RXQ
        Unlocked
        • wahoo28
          • Apr 2025
          Unlocked
          Thank you so much!!
          Just a question, the BIOS now starts up in Manufacturing Program Mode with a counter, do I need to do anything else now?
          Also - if it is useful for future reference...
          After resoldering both chips, the laptop kept this screen flashing behaviour, however it only did so after the initial HP Wolf Security splash screen. It felt as if there was something hardware-related that intervened _after_ this very initial splash screen was passed.
          I disconnected everything from the motherboard (keyboard, touchpad, etc.) and restarted it exclusively with the usb-c connector giving power and connecting mouse, keyboard and screen via docking station.
          This configuration did not caused any more screen flashing.
          I re-connected the various peripherals one by one - the culprit is most definitely related to the USB-A and audio jack board. I am still not 100% sure if it is the board itself (which had quite a lot of corrosion signs before I cleaned it), the "USB wire cable" (which actually looks fairly intact) or just the ribbon cable "13MB-13USB" that has definitely some ruined tracks. I will try searching for a ribbon cable spare first...
          • trungb271
            • Jan 2024
            • 6
            • Việt Nam
            Hello sir, please help me fix my HP Probook 635 aero G8, HP Endpoint Security Controller Problem
            SN: JPH231Lk8S
            • lapfix
              • Mar 2020
              • 2720
              • my workshop
              SN: JPH231Lk8S
              post main bios
              • studdy05
                Bricked HP Probook 450 G7 Bios questions
                by studdy05
                Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                Ive got...
                07-08-2025, 09:24 PM
              • macabook
                by macabook
                🧩 Initial Issue
                07-24-2025, 02:17 PM
              • bajdik
                HP ProBook 635 Aero G8 - power on with only 0.02A - fix empty BIOS please
                by bajdik
                Laptop powering with only 0.02A load.
                No short circuit found, so I try to read BIOS.
                It looks very "empty", isn't it?
                Can anyone check it, please?
                This is my dump from CH341A.
                Model: HP ProBook 635 AERO G8, S/N: 5CG1342VLN, ID: 43A50EA#BCM
                Thank you for your time....
                03-15-2025, 11:34 AM
                by Vesko356
                08-11-2023, 03:27 AM
              • the_raz
                Need (unlocked) bios for HP Probook 450 G3 Notebook
                by the_raz
                I'm requesting a bios .bin for 2 of my hp Probook 450 G3's. Both of which I had forgotten the bios passwords. I stupidly flashed both of them with firmware "made" by the RCUnlocker software and I guess I shouldn't have. The last thing I did was flash both of them with RCUnlocker-fw thinking it would 100% work and left my programmer etc behind and won't have access to them for another 2 days so I figured I'd create a thread to see if I'd be so lucky that someone might have a working file laying around 😝
                Laptop number 1:
                Model: HP ProBook 450 G3
                Motherboard part number:...
                12-17-2024, 03:37 PM
