Nitro AN515-51 bios please
  • hazem3636
    • Jun 2022
    • 35
    • sa
    hi there i need your help to get clean dump file for Acer laptop the original bin file attached and the laptop info down , thanks for your help .
    Nitro AN515-51
    Model Number: AN515-51
    Serial Number : NHQ2REM0037430EC983400
    Warranty Expiration: 30 Dec 2018​
  • hoaca388
    Badcaps
    • Jan 2022
    • 12406
    Nitro AN515-51
    Nitro AN515-51
    • hazem3636
      • Jun 2022
      • 35
      • sa
      hi there , hoaca388 how are u doing sir , thanks for your support .
      sorry but the isuue still not solved , am wondering in your attached file there is EC.bin file what is the perpous of this file . and i would like to know how sould i sater to do troubleshooting ,
      the laptop is power on and there is heat from the prossessor and the fan is spining at full speed for 3 minits and shutdown again , i press power on and spining and stop like that only​
      • hoaca388
        Badcaps
        • Jan 2022
        • 12406
        Looks like it's flashing for I/O. I'm not familiar with this either.
        • to5it0
          by to5it0
          10-24-2025, 01:35 AM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • maanee11
          Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
          by maanee11
          Hello Everyone,
          I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
          It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
          In the website, you can only see specs etc.
          I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
          11-08-2025, 04:08 AM
        • m1ch43lzm
          by m1ch43lzm
          Hi everyone
          09-06-2025, 05:47 PM
        • Forest79
          by Forest79
          07-23-2023, 07:39 AM
