LENOVO 300e Gen2 Bios Password
  • AncientRocks78
    • Feb 2025
    • 11
    • Morocco
    Hi there, can anyone help me to clean bios password please, i'll be very grateful?
    My Laptop is:
    Lenovo 300e 2nd Gen
    Model : 81M9
    S/N : R911S76T
    MTM : 81M9S03300
    Board : BM5860_V1.3A
    I attached the Bios Dump 9ZCM51WW, thank you in advance
  • hoaca388
    Badcaps
    • Jan 2022
    • 12420
    My Laptop is:
    Lenovo 300e 2nd Gen
    Model : 81M9
    S/N : R911S76T
    MTM : 81M9S03300
    Try
    • AncientRocks78
      • Feb 2025
      • 11
      • Morocco
      Originally posted by hoaca388
      Try
      Hi, thank you for the help! Unfortunately, after i flashed the bios, the screen stays off while the laptop running! I don’t know what’s wrong, but had several attempts flashing this night with my only CH341A, which doesn’t recognize it perfectly! I was using it with the clip, for info
      • AncientRocks78
        • Feb 2025
        • 11
        • Morocco
        The chip reading was my fault, because, i did not plugged the USB-C charging port, so the chip can have enough voltage! Now i'm sure that the chip is properly flashed with the BIOS, and the reading is done and shows the exact data. Even when reading it many times, it shows same thing. But the screen stays always off, while the laptop is on!
        I didn't powered it from before yesterday until after the flash, but what i did, before yesterday, is shorting two capacitors beside the CMOS Battery connector: 14 and C15. Will what i did is the cause of the BlackScreen?
        • AncientRocks78
          • Feb 2025
          • 11
          • Morocco
          Hello again,
          Now on my desktop, i've just checked up my dumped bios bin, and found that it was corrupted dump by the CH341A, and that i had to connect the USB-C charging cable in order to make a good dump. Now, i don't have any other dump than that, would it be possible to rebuild the bios file so i can flash it back? Please, help me out!
          I've attached the UEFITool Messages screenshot from my corrupted bios image dump, and a example of the same model from another topic attachement request BIOS file
          • hoaca388
            Badcaps
            • Jan 2022
            • 12420
            Hello again,
            300e 2nd Gen Notebook (Lenovo) (Type 81M9) - Type 81M9
            • AncientRocks78
              • Feb 2025
              • 11
              • Morocco
              Hello again,
              I'm very gratefull as this BIOS file revived my laptop, as i've decided to desolder the chip, write the file on it, and solder it back! Everything was smooth, but on the setup screen, the BIOS shows (OA3 Key ID: Not defined) and "M829RRFF" as a S/N which is not mine. My S/N is:R911S76T
              How please can i put back these infosin the DMI or Write them directly to the BIOS file. For info, my Windows key is the one on the dump file i've uploaded yesterday!
              • hoaca388
                Badcaps
                • Jan 2022
                • 12420
                Hello again,
                Serial number is not in bios.
Name:	2025-02-12 12_45_14-Settings.png
                • AncientRocks78
                  • Feb 2025
                  • 11
                  • Morocco
                  Thank you so much dear hoaca388 I which you that, all your hopes to be granted and executed!
                  • RMDUiFT
                    Should I buy a Lenovo Thinkpad E495 with bios password?
                    by RMDUiFT
                    Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
                    I have a few questions:
                    • If I would buy this laptop and have
                    08-25-2024, 09:00 AM
                  • zenius
                    by zenius
                    12-08-2024, 06:13 AM
                  • lucaszmn
                    by lucaszmn
                    Problem:
                    Initial Findings:
                    • I concluded that the
                    08-12-2025, 03:01 PM
                  • madrali
                    lenovo e15 gen2 bios ? problem
                    by madrali
                    Model: Lenovo ThinkPad E15 Gen 2 (Intel)
                    20TD-50S0KU00
                    Hi, my laptop suddenly shut down while it was running. When I try to turn it back on, the screen stays black and it emits a melodic beep.
                    I used Lenovo's SmartBeep decoder and it returned error 0284:
                    "TCG-compliant functionality-related error (possibly BIOS code validation failure)"
                    I then tried to enter crisis BIOS recovery mode by pressing Fn + R at boot. The melodic error code changes, but nothing else happens regardless of whether a USB is inserted. I receive another...
                    06-16-2025, 12:06 PM
                  • baaligoga
                    Help needed in unlocking BIOS Supervisor password - Lenovo X1 Yoga 5th Gen
                    by baaligoga
                    Good day, everyone!
                    I'm encountering an issue with my Lenovo X1 Yoga 5th Gen laptop related to the BIOS supervisor password. I'm seeking assistance and guidance from the knowledgeable members of this community in resolving this problem.
                    I am no expert and cannot perform soldering or unsoldering of the chip from the board. Therefore, I attempted to use an EZP 2023 programmer with a clip to extract the BIOS bin file without removing the BIOS chip from the motherboard. The BIOS chip has the following letters imprinted on it: "Winbond 25Q80DVNIG 2026". I used the...
                    05-20-2023, 09:48 AM
