DELL Inspiron 1750 bios request
  • XIII
    XIII
    • Mar 2024
    • 22
    • Tunisia
    Hello guys, i have this dell inspiron 1750 that arrived with a corrupted bios file, can anyone help me fix it out ? ive looked everywhere but couldnt find an
    thank you in advance.
    Reg type: P04E001
    Reg model: P04E
    SN: G9PTBL1​
    • 22284
    • XIII
      XIII
      • Mar 2024
      • 22
      • Tunisia
      Originally posted by SMDFlea
      Thank yuo much for the answer, unfortunately it turned out to be an ati graphic issue, after heating up the chip, the laptop came back to life, is there a way to disable the discrete ati graphics and only work with the intel one ? thank you in advance !
      • XIII
        XIII
        • Mar 2024
        • 22
        • Tunisia
        the bios is tested and working perfectly tho ! otherwise i need some help to convert discrete to uma if possible, thank you in advance!
        • zenius
          by zenius
          12-08-2024, 06:13 AM
        • GadgetsFix
          Dell Inspiron 16 5630 BIOS request
          by GadgetsFix
          I'm in need of a BIOS file for a Dell Inspiron 16 5630. Unfortunately, I don't have access to the original BIOS file as this is for a replacement BIOS chip installation.
          • Model: Dell Inspiron 16 5630
          • MainBoard Part Number: 4550SC01C004
          • Laptop Serial No: GKH3JX3
          • DP/N: 0303KM
          • QUAKE N RPL UMA CS MB
          • 213251-2
          • TMN0H$KB
          01-17-2025, 07:38 AM
        • rayeton
          Dell Inspiron 16 7630 BIOS request
          by rayeton
          I'm in need of a BIOS file for a Dell Inspiron 16 7630.
          Model: Dell Inspiron 16 7630
          QUAKE_RPL-H_GTX_16N_UMA
          223053-1
          TKP6T$KA
          MainBoard Part Number: 4910S9100007
          DP/N: 0WMG56
          ST: 44MNKX3
          The laptop fails to boot. A white LED light turns on for three seconds, then shuts off, repeating in a loop. Pressing the D key causes colors to display on the screen, but the laptop still does not boot afterward.
          Thanks in advance!​...
          04-04-2025, 03:14 PM
        • DavidChunco
          Dell G15 5515 Ryzen Edition Apparently Bricked BIOS Request
          by DavidChunco
          Hi, I hope someone can help me with this, my Dell G15 Ryzen Edition does not post anymore (black screen, no Windows boot, no BIOS screen) after Windows Update pushed what appears to be a buggy bios image, I've tried the following with no success:
          - Receive help from Dell Support (it is out of warranty).
          - Disconnect machine from AC power and battery overnight.
          - BIOS recovery process
          - Connected external display via HDMI
          - Disassembled machine and found bios chip, its a Gigadevice 25LR128DSIG (GD25LR128DSIG), at first I tried to get it detected by CH341A (with...
          03-15-2025, 11:00 AM
        • cr4zychriss
          by cr4zychriss
          • Rebrand: PC Specialist
          11-14-2025, 04:04 PM
