Dell Latitude 5550 (223111-1 K7W9K$JA) Admin Password
  • joselito
    • Mar 2015
    • 50
    • Philippines
    Please Help remove Admin password Dell Latitude 5550 223111-1 K7w9k$ja admin password.
    Tag: GXG1P54
    Thanks.
    • 22107
    Tag: GXG1P54
    Thanks.
    You made a bad backup, open it with a hex editor and you`ll see, its filled with zeros. Your file has compressed down to 543 Bytes.
    https://www.badcaps.net/forum/troubl...21#post1622421
    When flashing a BIOS always make a backup first. Take 2 or 3 different dumps and make sure they are identical.
    On Windows, you can use the command "fc /b" to check if two dumps are identical.
    Make sure that the dumps looks good, i.e. not filled with 0x00 or 0xFF. After compression, if the file has a size of only a few kilobytes, the EEPROM was most likely not read properly.
    Additionally, please read the FAQ at: https://www.badcaps.net/forum/showthread.php?t=98665
    Depending on the suffix, 8FC8 etc, you might be able to unlock it yourself ,that is if you can make a good backup first.. https://www.badcaps.net/forum/troubl...23#post1622423
    • joselito
      • Mar 2015
      • 50
      • Philippines
      Thank you. i will try that. its just 1st time using that ez2019 programmer.
      • adamgouadma
        • Jul 2017
        • 202
        • setif
        Please Help remove Admin password Dell Latitude 5550 223111-1 admin password.
        Tag: J5WMX64
        Thanks in advance
        • hoaca388
          Badcaps
          • Jan 2022
          • 12419
          Tag: J5WMX64
          Thanks in advance
          Unlocked
          • adamgouadma
            • Jul 2017
            • 202
            • setif
            Originally posted by hoaca388
            Unlocked
            Thank you, it worked, you're awesome
            • aykiki
              • Sep 2023
              please can i get admin password remove from dell latitude 5550 223111-1 K7W9K$KA bios file
                • 22107
                post S/N Service Tag or SNID, full name and model, motherboard model, backup etc.
                read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
                • Dan20701
                  • Sep 2020
                  • 204
                  Hello all, I have used Rex98_8FC8_Patcher on a Dell Latitude 5550 and its dead
                  I have not tested putting back the original yet , is Rex98_8FC8_Patcher working
                  ok on this model? I am uploading the original could some please remove the password.
                  ST-4Q34C64
                  Thanks so much.
                  • danito
                    • Jun 2016
                    • 1151
                    ST-4Q34C64
                    Thanks so much.
                    try
                    • punkrockpax
                      • Feb 2019
                      • 32
                      • Mexico
                      can anyone help me? i messed up, ive selected the wrong size and messed my backup... Ive tried post#5 it works but once shows dell logo, stays there 5 to 10 seconds then reboots
                      latitude 5550
                      ST:2PZ7R14
                      EX:5924367256
                      tnx
                      • Markus1741
                        • Sep 2020
                        • 965
                        • N/A
                        latitude 5550
                        ST:2PZ7R14
                        EX:5924367256
                        tnx
                        Try ....
                        • punkrockpax
                          • Feb 2019
                          • 32
                          • Mexico
                          Try ....
                          you dont know how much ifk love you, it worked! thnkyou! where can i send you a donation???????<3
                        • punkrockpax
                          • Feb 2019
                          • 32
                          • Mexico
                          Try ....
                          BTW i was struggling because bios was in RAID mode and the installation of this drive was normal in AHCI/NVME everthing ok, but suddenly popped something in windows that says "deviceFreeze-264" is this related to the instalation? or the bios was locked with something? i dont usually work with dell laptops
                          thanks in advance
                          • LBTT1121
                            • Nov 2024
                            • 1185
                            • Việt Nam
                            thanks in advance
                            Laptop active absolute / computrace, attach bios dump
                            • punkrockpax
                              • Feb 2019
                              • 32
                              • Mexico
                              I posted un #11 but, my dump is messedup, markus1741 helped me to build a newone, can you help me with this ill attach again the same messed dump, thanks in advance
                              • punkrockpax
                                • Feb 2019
                                • 32
                                • Mexico
                                Here is the info again, thank you
                                latitude 5550
                                ST:2PZ7R14
                                EX:5924367256
                                • Markus1741
                                  • Sep 2020
                                  • 965
                                  • N/A
                                  latitude 5550
                                  ST:2PZ7R14
                                  EX:5924367256
                                  Hello try this new one ......
                                  • punkrockpax
                                    • Feb 2019
                                    • 32
                                    • Mexico
                                    working but usbs disabled when enters to windows, you can boot from usb and its ok
                                    but once in windows usbs gets disabled
                                    • punkrockpax
                                      • Feb 2019
                                      • 32
                                      • Mexico
                                      bios is working correctly
                                      usb issue was software related, here i share the link that describes error and solution.
                                      https://www.dell.com/support/kbdoc/e...ts-do-not-work
                                      conclusion: is software related not firmware nor bios, thank you all
                                        DELL Precision 5550 Mobile workstation 5000 Specification for Upgrade or Repair
                                        This specification for the DELL Precision 5550 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5550 boardview and 5550 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Precision...
                                        09-06-2024, 08:10 PM
