insys YK1-140C device locked
  • lallollas
    • Feb 2017
    • 58
    • espaรฑa
    hello i have insys YK1-140C with this lock that you can see when every i install nerw windows and conect to wifi i restart and then device locked plz help
    SN : yk1140c009092
    bHAI HELP KAR DO
  • minhdigital
    • Nov 2022
    • 765
    • Vietnam
    SN : yk1140c009092
    bHAI HELP KAR DO
    Uploaded your backup bios
    • macsn
      • Mar 2017
      • Portugal
      go to this page :
      -https://cuco.inforlandia.pt/ucode/
      • Yolofolkss
        Asus X99-pro/usb 3.1 Usb overcurrent device reoccurring issue
        by Yolofolkss
        Hi this is a really odd case.
        I have removed all of the esd ic for USB 3.0 and 2.0
        I measured all of the data lines and 5v usb voltage lines there are no shorts
        all of the USB ports have no damage
        Clearing the bios using the jumper wont help.
        it is still showing USB overcurrent device
        the only temporary fix I've tried and worked so far is flashing the bios
        and the error is gone
        but when you start the motherboard with a USB device still attached
        the USB over current device error is back. the bios needs to be externally flashed...
        01-09-2023, 04:21 AM
      • mrdevil
        Crest Smart Home Single Power Adaptor SHSPM1 (rebadged Tuya device) - bad cap causing failure, how to repair
        by mrdevil
        Wanted to share this as I couldn't find anything on the internet about this problem, so pulled one apart and found the problem myself. Years ago I bought approx 20 or so Crest Smart Home Single Power Adapter smart switches - small 240v Tuya-compatible (rebranded) smart switch devices with power monitoring, which Big W had on sale for half price. Paid $7.50 each for these, and they've been incredibly useful for turning things on and off remotely... and monitoring how much power each device uses.
        However, after about 12 months, I had a number of these stop working...
        01-08-2025, 03:19 AM
      • Stachujones
        Dell XPS 13 9370 unknown USB devices in device manager
        by Stachujones
        Hello, i bought a faulty Dell xps 13 9370 after installing windows in device manager i Can see 2 unknown devices, one is thingerprint reader because it dissapears after i unplug it and second one is i believe bluetooth because it also doesnt work and in bios there is no bt also.
        Device manager says "unknown device, failed to request device descriptor"
        Can somebody point me in right direction what to check?
        I updated bios to the newest version and thunderbolt controller firmware still no luck
        04-05-2025, 07:35 AM
      • bohaboha
        how to install gl usb2.0 uvc camera device driver on windows 10
        by bohaboha
        Hello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encouโ€‹ntered an error.
        but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
        any help?
        01-26-2025, 08:33 PM
      • liquidzorch
        ideapad 15imh05 Intermittant no audio device
        by liquidzorch
        I have an ideapad gaming 3 15imh05 here that has an intermittant issue with audio. The device will dissapear from device manager randomly. Most of the time it does not work. I have tested the continuity of the SDATA_IN, HDA_SDOUT_AUDIO, HDA_BITCLK_AUDIO, and HDA_SYNC_AUDIO, all to the pch (or the resistors near it), and all lines are good. They have no voltage though ( I have not been able to test when it's working). HDA_RST# from the pch only goes to a capactor to ground and that's it, so it's not used. What other lines should I check? What lines ares used to detect the device?
        Thanks in...
        08-13-2025, 09:30 PM
