request unlock HP EliteBook 640 G11 password bios
  • Aditya11ttt
    replied
    try and feed back !!
    Originally posted by black0hackers
    I HAVE TEST 2 FILE. 1ST WORK BUT NOT BOOT TO MPM, STILL HAVE PASSWORD, 2ND DONT WORK
    i have one 640 g11 bios pass
    SN: 1H850824LY
    PROD ID: A58TVUC#ABA
  • black0hackers
    replied
    Originally posted by rex98
    can someone test this use the 1st one
    if it doesn't work use the second one.
    you should flash both main and EC
    and let me know if it boots to MPM thanks.
    SN: 1H850824LY
  • rex98
    replied
    Originally posted by VirVir
    You mean, that part should be replaced with FF or 00? For the moment I've gave up, due to lack of time and, after writing and rewriting the BIOS chip 4-5 times...it said enough and burned... I'm waiting for an order of 10 chips from AliExpress but it will take some time. Keep it touch 🤘🏻🖖🏻
    you should not remove the chip if just testing, just put jumper wire and use ISP in rf809f or h.
  • VirVir
    replied
    i know there's always a way. we haven't tried it yet. every security there's always a loophole. like this in g11 EC its very similar VSSTORE in bios main i haven't tried this yet, if i only have G11 laptop here i would try all possible means.
  • rex98
    replied
    Hello guys! Found some troubling info about the HP security from 2024 onward:
    HP Endpoint Security Controller 2024
    Attacks against PC firmware are on the rise. Unfortunately, protecting the PC BIOS and other critical firmware is often not seen as a priority. HP addresses this with our Endpoint Security Controller (ESC), a dedicated chip that validates the integrity of the BIOS and other firmware to enhance the security of every HP business-class PC. The ESC validates that the firmware is not infected by malware before the CPU is allowed to boot. If any corruption has been detected, it will restore a clean copy held in the ESC's isolated flash. HP is the only vendor offering this unique security solution as a standard part built into business-class PCs to safeguard our customers against IT security threats.
    Bottom line is...no matter if you can "unlock" the main BIOS as long as the ESC provide a backup and restore the old blocked BIOS before you can access it...
  • VirVir
    replied
  • rex98
    replied
  • mesdova
    replied
    Originally posted by mesdova
    need unlock and patch
    HP ELITEBOOK 640 G11
    SN: 5C4377dfl
    PRODID: 901d4av
    bump
  • VirVir
    replied
    Tried another way. Basically I've replaced the entire ME Reg part of the BIOS with info from a Firmware recovery file from the HP site. After more than one hour everything was done 👍🏻 Laptop starts and...informed me about the mismatched information and that it's doing a quick recovery ... after two restarts, the password is there of course 😖😖😖 How the h*LL can I stop it from doing this sh*t recovery? I didn't find any cmos battery on this model, the power is out long enough....How does it remember?😢😢😢
  • VirVir
    replied
    Originally posted by hoaca388
    HP EliteBook 640 14 inch G11 Notebook PC
    CT Number_6TDWV0B81K2L4R
    Serial_5CD4441CK3
    Sku_B3FD3EC#ABD
    Build Id_24WWREBZ601#SABD#DABD
    Fearture byte_476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUcAeMfPguhKhkjhk8mEmVn7nVpDpTpnpqprqDqzrNrXrbs4.yF
    Hope it unlocks. Goodluck.
    Unfortunately doesn't work 😔 Some error appeared telling me that the BIOS makes some recovery from the embedded memory due to mismatch ID information...only one option and that was to click "OK" , after 2 minutes the laptop restarted and the password is still there. This is so annoying 😖😖😖 Anyway, thank you for helping!
  • hoaca388
    replied
    Hello everyone! I have this Laptop with a locked BIOS 😔 I've tried unlocking the EC file but it's "Missing unlockable content" so...main BIOS, split in 2x16Mb files, RCUnlocker said it's unlocked, spits a *_unlocked.bin file, reunite the flies in a 32Mb file but... nothing changed. Verified with CMD certutil -hashfile but it's the same file as the original 🤷🏻 what's up with that? Can someone please help? 🙏🏻 Thank you 🙏🏻
    5CD4441CK3 B3FD3EC#ABD
    MODEL:X8V
    DA0X8VMB8G0 REV.G
    Serial_5CD4441CK3
    Sku_B3FD3EC#ABD
  • VirVir
    replied
    MODEL:X8V
    DA0X8VMB8G0 REV.G
  • mesdova
    replied
    SN: 5C4377dfl
    PRODID: 901d4av
    commented on 's reply
    You MUST:
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
  • anhbanxoi
    replied
    Originally posted by donal310
    Hello everyone, I hope you can help me remove the password. I am attaching the file and my computer's data. Thank you very much.
    SN: 5CD438FGJG
    PRODID: A6UW6UC#ACH
    Try
    Product Name : HP EliteBook 640 14 inch G11 Notebook PC
    Serial Number: 5CD438FGJG
    SKU : A6UW6UC#ACH
    BuildID : 24WWREAZ601#SACH#DACH
    Feature Byte : 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUcAeMfPgSguhKjhk8mEmVn7nVpDpVpnpqprqDqzrXrbs4.Ra
    System Board CT Number : PTXMK028JK10NC​
  • donal310
    replied
    Originally posted by peste
    post S/N, full name and model, motherboard model, product number,etc
    Hello friend, could you help me with my file? I have attached everything needed in my comment above.
  • donal310
    replied
    Originally posted by SMDFlea
    Type the laptop seial number, full name and model, motherboard model, etc.
    read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
    replied
    Originally posted by salim1gr
    Hi
    please unlock hp 640 g11
  • salim1gr
    replied
    Hi
  • peste
    replied
    Originally posted by azizi abdelhak
    plz i need unlock bios hp 640 g11
  • zenius
    by zenius
    12-08-2024, 06:13 AM
  • overclocker1786
    [Bios Password Unlock Request] [Dell OPTIPLEX SFF PLUS 7020] [8FC8 method]
    by overclocker1786
    Hello I have a dell optiplex SFF plus 7020 with a password that I recovered from e-waste. It is possible to get the password removed via the bios patch method? I managed to dump the 32MB bios chips and would like help patching it to MFG mode so I can clear the password.
    Thanks.
    1hj4z24 = Service tag
    A schematic would also be amazing if anyone has one!...
    08-31-2024, 08:46 PM
  • traxformania
    TONGFANG "GM7TG7P" Bios Password Problem?
    by traxformania
    I tried :
    -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
    11-15-2023, 07:32 AM
  • BlackVisor
    How to Decode BIOS password for RedmiBook Pro15 2022 6800H
    by BlackVisor
    RedmiBook Pro 1542022 6800H
    SKU: TM2113-39463
    Model Number: RMA2204-AB
    CMIIT ID: 2022AP1835
    SN: 39463/22WD01355
    BIOS version: RMARB5B0P1010 20230628
    1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
    2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
    3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...
    01-14-2024, 06:35 AM
  • outsider
    Panasonic FZ-G1 MK5 - BIOS password returning
    by outsider
    Hello
    I removed the BIOS password thanks to the help of one of the friends of this forum.
    https://www.badcaps.net/forum/troubl...61#post3637661
    The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
    06-17-2025, 12:51 AM
