Bios unlock for Asus Vivobook X513EA
  • electrono
    • Jul 2024
    • 11
    The situation is as follows:
    I set a supervisor password for my bios and forgot it because my laptop boots directly into Windows. So apparently there is no need to remember the password, my brain thought, so here I am
    System Specs:
    • Operating System: Windows 11 Pro 64-bit (10.0, Build 26100) (26100.ge_release.240331-1435) (Updated from original Windows 11 Home to 11 Pro using a key)
    • System Manufacturer: ASUSTeK COMPUTER INC.
    • System Model: VivoBook_ASUSLaptop X513EA_K513EA
    • BIOS: X513EA.310 (Type: UEFI)
    • Processor: 11th generation Intel(R) Core(TM) i5-1135G7 @ 2.40GHz (8-core), ~2.4GHz
    Further Information:
    • Storage Device: Type SPI
    • RPMC Replay Protection Max Rebind 15
    • BIOS Read Access 0x000F
    • BIOS Write Access 0x000A
    • GBE Read Access 0x0009
    • GBE Write Access 0x0008
    • ME Read Access 0x000D
    • ME Write Access 0x0004
    • EC Read Access 0x0101
    • EC Write Access 0x0100
    I read the topics on badcaps and win-raid to gather as much information as possible to dump my bios into a file (and succeeded?). I have attached the dump files. One was created with afuwinx64.exe and the other with Intel's fptw64.exe. I also checked the checksums of some of the files generated and they are identical (so hopefully no mistake there).
    I tried to decrypt the pw using the https://www.badcaps.net/forum/troubl...=2#post1544866 guide, but failed.
    Click image for larger version  Name:	Screenshot 2025-01-11 215513.png Views:	0 Size:	29.0 KB ID:	3546482
    When I run the AMITSEDecrypt.py file, I get a "weird" decrypted password (it does not work)
    TLDR:
    My request: Could one of you please look at these bios dump files and decrypt the passwords (or tell me if they are completely wrong)?
    Kind regards
  • hoaca388
    Badcaps
    • Jan 2022
    • 12122
    System Specs:
    TLDR:
    Kind regards
    Come here
    Click image for larger version  Name:	Screenshot 2025-01-11 215513.png Views:	0 Size:	29.0 KB ID:	3546594
    • electrono
      • Jul 2024
      • 11
      Hi, thanks for getting in touch.
      So, the first input password would be "7D 46 D3 1A 4B 5A 71 DD B4 5A 6A 54 22 E2 41 E7 7F 01 87 E1 C7 C1 64 29 15 71 E0 E8 F2 91 12 DC" (without the spaces). How do I trim the other input to decrypt the password? I've tried trimming the second input at the front and back, but output contains ASCII characters that are not printable
      TLDR: I've tried XORing, but no luck http://xor.pw/
      5B 93 B6 26 11 BA 6C 4D C7 E0 22 74 7D 07 D8 9A 33 2E 8E C1 E9 54 44 E8 9F 7B FA 0E 55 A2 B0 35
      C7 E0 22 74 7D 07 D8 9A 33 2E 8E C1 E9 54 44 E8 9F 7B FA 0E 55 A2 B0 35 0B C9 66 5C C1 EF 1C 83​ (spaces are a little messed up)
      Decrypt code:
      5B93B62611BA6C4DC7E022747D07D89A332E8EC1E95444E89F7BFA0E55A2B0350BC9665CC1EF1C83
      Error:
      In the output string, there are ASCII characters that are not printable. Use another output type to view the complete output.
      Got any other ideas?
      • hoaca388
        Badcaps
        • Jan 2022
        • 12122
        Decrypt code:
        Error:
        This password cannot be decrypted, for now. You can remove it but you should have a programmer to extract the entire bios file.
        • electrono
          • Jul 2024
          • 11
          Hey,
          I've got some more stuff to post. I took my laptop apart and managed to identify the BIOS chip (see attached picture). I haven't looked at the back of my motherboard yet, but I reckon this is the chip I'm looking for. Do you think you could take a look and let me know if I'm right?
          My baseboard is as follows: ASUSTeK COMPUTER INC. X513EA M938NBCV00U06EMB 1.0
          I've found an eBay listing with a picture of the whole motherboard: https://www.ebay.de/itm/266902106201
          How I would proceed:
          I've bought the CH4131A programmer and will read the BIOS chip with it.​
          Best regards!
          • Ali_Khan
            • Dec 2023
            • 13
            • Egypt
            System Specs:
            TLDR:
            Kind regards
            HERE
            • electrono
              • Jul 2024
              • 11
              Thank you.
              You are right. You have "erased" the data by writing zeros into it. However, flashing this file with fptw64.exe is not possible because of the bios protected regions. I would do this with the programmer (after some experimentation on a bricked laptop I got)
              I have another question:
              Is it possible to flash the latest bios compatible with my motherboard from Asus? See this link: https://www.asus.com/searchresult?se...0K513EA&page=1
              Edit: But back to the main topic: Is the chip the right one?
              • electrono
                • Jul 2024
                • 11
                Hello Guys,
                i am back after quite some break. I have extracted the bios using the Ch314a programmer (files attached for every chip version, read1 -> first in list etc)
                I have read the bios chip using ASProgrammer 2.1.2, and compared the data through certutil, for these specific chip versions (MX25L12833F/MX25L12835F/MX25L12845E/MX25L12865E/MX25L12873F)
                The extracted encrypted password is still the same. }FÓKZqÝ´ZjT"âAç‡áÇÁd)qàèò‘Ü or 7D 46 D3 1A 4B 5A 71 DD B4 5A 6A 54 22 E2 41 E7 7F 01 87 E1 C7 C1 64 29 15 71 E0 E8 F2 91 12 DC
                Thus i am thinking of reflashing my chip like Ali_Khan suggested.
                For this i am trying to get rid of the "gibberish" that starts 006474D0 and filling it with 00.
                Is this the right approach?
                SMDFlea , hoaca388, Ali_Khan
                Thanks in advance for your responses
                • electrono
                  • Jul 2024
                  • 11
                  I am closing this topic as I have regained access to my bios.
                  It worked with the approach Ali_Khan suggested.
                  I modified a Bios file I was reading with the programmer and just replaced the encrypted password with zeros. After that i flashed it with the programmer. (i did a checksum check before flashing with UEFITools_NE)
                  If anyone encounters a similar problem, I am happy to help. Thanks.🤺
                  • zenius
                    by zenius
                    12-08-2024, 06:13 AM
                    ASUS VivoBook X513EA-BQ349T Notebook 15 Specification for Upgrade or Repair
                    This specification for the ASUS VivoBook X513EA-BQ349T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X513EA-BQ349T boardview and X513EA-BQ349T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                    09-06-2024, 10:00 PM
                  • macabook
                    by macabook
                    🧩 Initial Issue
                    07-24-2025, 02:17 PM
                  • greelidd
                    K6604J Vivobook RTX 4070 BIOS Dump Request
                    by greelidd
                    Hi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
                    Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didn’t work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i can’t find a clean BIOS that’s a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...
                    09-01-2025, 06:14 PM
                    ASUS VivoBook X513EA-BQ1281T Notebook Specification for Upgrade or Repair
                    This specification for the ASUS VivoBook X513EA-BQ1281T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X513EA-BQ1281T boardview and X513EA-BQ1281T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                    09-07-2024, 01:30 AM
