HP 16-WF0007TX
  • ak1_2004
    • Oct 2017
    • 42
    • Iran
    HP 16-WF0007TX
    hello
    The laptop is turned off during the BIOS update and it turns on with the attached BIOS and works properly, but without battery!
    If I connect the battery after turning on the laptop, the laptop works correctly with the battery, but when I turn off the laptop, it only turns on again if the battery is removed and the BIOS of the laptop is reset.
  • shiyab
    • Sep 2023
    • 1696
    • india
    Originally posted by ak1_2004
    hello
    If I connect the battery after turning on the laptop, the laptop works correctly with the battery, but when I turn off the laptop, it only turns on again if the battery is removed and the BIOS of the laptop is reset.​
    post backup bios
    • ak1_2004
      • Oct 2017
      • 42
      • Iran
      Backup
      • shiyab
        • Sep 2023
        • 1696
        • india
        Backup
        hi try this new
        • ak1_2004
          • Oct 2017
          • 42
          • Iran
          hello
          The previous problem has been solved and the laptop turns on with this BIOS, but it seems that after closing the monitor and opening the laptop again, it does not turn on properly.​
          • 964758
            • Jul 2017
            • 40
            • Georgia
            Hello friends! Can anyone tell me the model of the BIOS chip ?
            I have HP 16-WF0032TX laptop. Motherboard: LA-M783P REV:2.0, 2023-05-26.
            I'm guessing it's Winbond 25R128JVSN. Thank you very much in advance!
            • 964758
              • Jul 2017
              • 40
              • Georgia
              25R128JVSN
                • 22289
                Originally posted by 964758
                25R128JVSN
                Yes. Post your backup and also the laptop serial number
                • 964758
                  • Jul 2017
                  • 40
                  • Georgia
                  Laptop serial number is : CND3321YBP
                  I have a similar situation as from post #1
                  • 964758
                    • Jul 2017
                    • 40
                    • Georgia
                    And one more question, how to find out the BIOS chip on a laptop with or without OTP?
                    • superautomation
                      • Oct 2016
                      • Pakistan
                      plz help me IC no (PU301)
                      • peste
                        peste commented
                        Editing a comment
                        here "bios only requests"...move, we were discussing in the main forum...this post will be deleted...
                    • Bloodhoundje
                      HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
                      by Bloodhoundje
                      I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
                      I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
                      After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
                      I have desoldered the bios chip (GigaDevice...
                      03-16-2024, 03:12 PM
                    • JoWed
                      Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                      by JoWed
                      Hello Community,
                      I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                      07-01-2025, 09:32 AM
                    • yaya3gmax
                      Laptop Power Issue – Works on Battery, Fails on Adapter Load
                      by yaya3gmax
                      Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
                      Symptoms:
                      • Laptop works normally on a pre-charged battery.
                      • Battery does not charge when adapter is connected.
                      • Without battery:
                        • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
                        • Speakers “pop” when power cut occurs indicating harsh sutdown.
                        • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
                      08-21-2025, 07:16 AM
                    • legendkray
                      BIOS Help Regarding GM5IX7A-GM6IX7A Origin Laptop
                      by legendkray
                      I have OriginPC EON 15SL, however, my laptop starts and shutsdown after 1-2 second. Keyboard leds are coming on then fans spinning then it shutsdown and not turning back on unless I plug out the power cable and plug it in. I had issues with bricked BIOS then I flashed BIOS I got from the vendor to the SPI chip and still it didn’t worked because my EC firmware was newer than the BIOS I have flashed. So I wanted to try flashing the EC chip with the correct firmware that matches with the BIOS also from the vendor and it worked everything was well, and then stupid me wanted to unlock some...
                      07-05-2025, 09:25 AM
                    • Bowline
                      by Bowline
                      06-11-2025, 10:13 AM
