HP Dragonfly 13.5 inch G4
  • Raducosmin
    • Feb 2018
    • 14
    • Romania
    Can you help me with password remove please?
    SN: 5CG3497HLQ
    PRODUCT: 9C8X4EC
    • hoaca388
      Badcaps
      • Jan 2022
      • 12328
      SN: 5CG3497HLQ
      PRODUCT: 9C8X4EC
      HP Dragonfly 13.5 inch G4 Notebook PC
      CTNumber6MBMK0CTZIQ41A
      Serial_5CG3497HLQ
      Sku_9C8X4EC#ABU
      Fearture byte_476J6S6b7B7H7M7R7W7m7saBaEapaqauawcAeMfPfXguhKhZj4jhk8mEmVn7nVngpDpVpWpnpqprqMqkqxqzr4.RD
      Build Id_23WWSABZ602#SABU#DABU
      • Raducosmin
        • Feb 2018
        • 14
        • Romania
        Serial_5CG3497HLQ
        Sku_9C8X4EC#ABU
        IT WOKRS! THANK YOU VERY MUCH!
        • MAREBELE
          • Jan 2023
          • 41
          • Indonesia
          SN: 5CG3160404
          PRODUCT: 841W8AA#ABA
          help me to modify the Bios after CPU Swap form i7 1365U to i7 1355U
          • MAREBELE
            • Jan 2023
            • 41
            • Indonesia
            The EC on this is npcx998 The board doesn't turn on at the moment even after clean the me. I doesn't know how to clean the nvram, maybe that would help.
            The replacment cpu is prom a known good motherboard so I can cross the possibilities off a bad donor
            If possible please help me.
            Thanks in advance
              • 21869
              From what make/model of motherboard did it come from.
              • MAREBELE
                • Jan 2023
                • 41
                • Indonesia
                #27
                its from dell vostro 3530 / LA-M367P,
                additional info:
                The board is charging
                  • 21869
                  additional info:
                  The PCH has intel boot guard. You could only use that SOC as a donor for another dell
                  • MAREBELE
                    • Jan 2023
                    • 41
                    • Indonesia
                    #29
                    i have a few other board but its all dell board,i also have HP and Lenovo but it i7 1360P not U,
                    does all dell PCH is boot guarded?,
                    and also is it not possible to dissable the boot guard thru bios modification?
                    • MAREBELE
                      • Jan 2023
                      • 41
                      • Indonesia
                      #30
                      i got my hand on HP Elitebook G10 and swap The CPU from there after clean the me the board is turn on. Thanks for the support
                      • vik1100
                        • Sep 2021
                        • 6
                        • europa
                        #31
                        While desoldering the BIOS chip on motherboard [HP Dragonfly G4 , 5CG4425PBB], I might have accidentally removed a nearby SMD component.
                        I’m attaching close-up photos of the area.
                        Could anyone identify what part should be here (resistor, capacitor, diode, etc.) and its value?
                        Also, will the board boot without it, or is it critical?
                        Thank you in advance!
                        • vik1100
                          • Sep 2021
                          • 6
                          • europa
                          #32
                          I have an HP Dragonfly 13.5" G4 (SN 5CG4425PBB) which does not start.
                          Symptoms:
                          - When I press the power button, the screen stays black.
                          - The power LED blinks 7 times in a repeating cycle.
                          - No reaction on external display.
                          - Tried key combos (Win+B, Esc+F2) for BIOS recovery – no success.
                          - Full power reset (battery disconnected, power button 30 sec) – no effect.
                          What I suspect:
                          Looks like a corrupted BIOS.
                          Questions:
                          1. Does 7 blinks on Dragonfly G4 really mean BIOS failure, or could it be something else?
                          2. Does anyone have a clean BIOS dump for this model / same motherboard?
                          Any help or a working dump would be greatly appreciated.
                          • src8324
                            • Nov 2022
                            • 9
                            Hi SIr , could you please unlock this bios for me?
                            • peste
                              • Dec 2016
                              • 13573
                              • ROMANIA
                              #34
                              post the original contents of the bios chip..
                              post S/N, full name and model, motherboard model, .product number,etc.
                                • 21869
                                Damaged traces ?
                                • src8324
                                  • Nov 2022
                                  • 9
                                  thanks for replying. Can you Please remove the admin password ?
                                  product name: HP Dragonfly 13.5 inch G4 Notebook PC (91T60EC)
                                  SN: 5CG4351DNC
                                  • shiyab
                                    • Sep 2023
                                    • 1605
                                    • india
                                    #37
                                    SN: 5CG4351DNC
                                    hi try
                                    • Yakor2011
                                      HP Elite Dragonfly 13.5 inch Chromebook (6M5H6UC) (da00grmbai0)
                                      by Yakor2011
                                      does not turn on. There is a reaction to the power button: the consumption rises to 0.10 A, some of the voltages rise, and after a minute everything turns off. The resistances are normal.
                                      Please share the bios.
                                      07-01-2025, 03:52 AM
                                      HP ZBook Firefly 16 inch G10 Notebook Specification for Upgrade or Repair
                                      This specification for the HP ZBook Firefly 16 inch G10 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 inch G10 boardview and 16 inch G10 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                      09-07-2024, 07:20 AM
                                      09-07-2024, 07:19 AM
