HP Dragonfly 13.5 inch G4
  • nefaa.ben.jeddou
    • Oct 2024
    • 39
    • Tunisie
    hi i have hp dragonfly g4 with password bios protected
    any help plz thx for advance
    HP DragonflyG4 i7-1365U1332GB/512LTE5GPC (9T5U2PC)
    Serial: 5CG4052X6N
    Product: 9T5U2PC
    with original dump attached
    sorry for my bad english
    thx in advance
  • hoaca388
    Badcaps
    • Jan 2022
    • 12420
    Serial: 5CG4052X6N
    Product: 9T5U2PC
    thx in advance
    File's corrupted.
    • nefaa.ben.jeddou
      • Oct 2024
      • 39
      • Tunisie
      thx
      this backup is ok
      • nefaa.ben.jeddou
        • Oct 2024
        • 39
        • Tunisie
        Originally posted by hoaca388
        File's corrupted.
        can you help me i have uploded good dump
        • hoaca388
          Badcaps
          • Jan 2022
          • 12420
          HP Dragonfly 13.5 inch G4 Notebook PC
          CTNumber_6MBMK0DTZIV2S0
          Serial_5CG4052X6N
          Sku_9T5U2PC#ABU
          Fearture byte_476J6S6b7B7H7M7R7W7m7saBaEapaqauawbhcAfPfXguhKhZjhk8mEn7nVngpDpVpWpnpqprqMqkqxqzr4.2g
          Build Id_23WWSABZ602#SABU#DABU
          • nefaa.ben.jeddou
            • Oct 2024
            • 39
            • Tunisie
            Serial_5CG4052X6N
            Sku_9T5U2PC#ABU
            working like charme
            thx
            • Udemzy
              • May 2017
              • 166
              • Guatemala
              kindly help me unlock this HP dragonfly g4
              S/N-= 5CG4234TSY
              product id=6Q258AV
              • hoaca388
                Badcaps
                • Jan 2022
                • 12420
                S/N-= 5CG4234TSY
                product id=6Q258AV
                CTNumber_6MBMK0DTZJC0JN
                Serial_5CG4234TSY
                Product_6Q258AV
                Fearture byte_476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbhcAfPguhKhZj4jhk8mEn7nVngpDpVpWpnpqprqMqkqxqzr4.Md
                BuildId_23WWSACZ601#SACQ#DACQ
                • Udemzy
                  • May 2017
                  • 166
                  • Guatemala
                  Serial_5CG4234TSY
                  Product_6Q258AV
                  Works perfectly, thank you.
                  I appreciate.
                  • Udemzy
                    • May 2017
                    • 166
                    • Guatemala
                    pls kindly assist with unlocking this one
                    hp dragonfly g4
                    s/n=5CG4234TSX
                    prodID=6Q258AV
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12420
                      hp dragonfly g4
                      s/n=5CG4234TSX
                      prodID=6Q258AV
                      CTNumber_6MBMK0DTZJC0GY
                      Serial_5CG4234TSX
                      Product_6Q258AV
                      • Udemzy
                        • May 2017
                        • 166
                        • Guatemala
                        Serial_5CG4234TSX
                        Product_6Q258AV
                        thank you it work.
                        • Udemzy
                          • May 2017
                          • 166
                          • Guatemala
                          Hello, I noticed some keys and the mouse pad don't work anymore after programming this files, will it work if I update the firmware?
                          • Udemzy
                            • May 2017
                            • 166
                            • Guatemala
                            Pls can you help me build this file.
                            S/N = 5CG4234TSY
                            Hp dragonfly 4
                            • EthanMai
                              • Jul 2020
                              • 103
                              • 美国
                              Serial Number : 5CG4234TSX
                              Product Number : 6Q258AV
                              Description : HP Dragonfly G4
                              Need to clean, Thank you!​
                              • shiyab
                                • Sep 2023
                                • 1647
                                • india
                                complaint...?
                                  • 22119
                                  That serial is the same as the bios at post 10. What is the serial number of your own laptop .............. .Clean what ? ,explain what the problem is
                                  • EthanMai
                                    • Jul 2020
                                    • 103
                                    • 美国
                                    I used file #10 and it booted very slowly. It turned out that the motherboard had no chips.
                                    SN: 5CG341213G
                                      • 22119
                                      SN: 5CG341213G
                                      That is something you should have mentioned. Clean the ME firmware, it should fix the slow boot.
                                      • EthanMai
                                        • Jul 2020
                                        • 103
                                        • 美国
                                        OK, I'll bring it up next time. Would you like to help me?
                                        • Yakor2011
                                          HP Elite Dragonfly 13.5 inch Chromebook (6M5H6UC) (da00grmbai0)
                                          by Yakor2011
                                          does not turn on. There is a reaction to the power button: the consumption rises to 0.10 A, some of the voltages rise, and after a minute everything turns off. The resistances are normal.
                                          Please share the bios.
                                          07-01-2025, 03:52 AM
                                          HP ZBook Firefly 16 inch G10 Notebook Specification for Upgrade or Repair
                                          This specification for the HP ZBook Firefly 16 inch G10 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 inch G10 boardview and 16 inch G10 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 07:20 AM
                                          09-07-2024, 07:19 AM
