ASUS zenbook 14 oled - UX3402Z
  • ujhazi
    • Jul 2024
    • 17
    Hi there!
    May I ask a working BIOS for this laptop:
    ASUS Zenbook 14 oled UX3402Z
    sn: n7n0Lp01x868284
    I attached the original from the board.
    Many thanks
  • ujhazi
    • Jul 2024
    • 17
    Please
      • 21961
      Originally posted by ujhazi
      Please
      Post a picture of the white QR code near the speaker connector
      • ujhazi
        • Jul 2024
        • 17
        Here is the content of it:
        ,N626NBLP000B3WMB,UX3402ZA,60NB0WC0-MB2310,200,
        thanks
        • pbls
          • Apr 2019
          • 12
          • Russia
          Also want to programm working BIOS with clear ME for this model - UX3402Z
          Can someone help to upload this file here
            • 21961
            Post your backup ,full laptop model number and serial number. Please type the serial number https://www.badcaps.net/forum/troubl...before-posting
            • pbls
              • Apr 2019
              • 12
              • Russia
              - "Post your backup ,full laptop model number and serial number. Please type the serial number https://www.badcaps.net/forum/troubl...before-posting"
              - Sorry fo my inattention, next time I'll be post serial in first message. Thanks a lot fo the answer to my question. But I think there are no reason to upload dump or backup because someone in previous repairing center programmed and soldered this IC with BIOS and right now there is a wrong version of BIOS I'm sure. Serial: N4N0LP00W77515E Model placed on the bottom cover - UX3402Z, Mainboard name - NB5936_MB_V3
              Will it be enough to look for the BIOS?
                • 21961
                From your serial number i found your full laptop model number UX3402ZA-KM020W . Its the OLED version. There are different UX3402ZA​ bios updates at asus support. Post your backup anyway, as even if its the wrong one we might be able to rebuild it.
                • pbls
                  • Apr 2019
                  • 12
                  • Russia
                  Hello again, SMDFlea! Nice to see a message from you. This is mine dump in attachment. And can you answer to me - Is there any risk to programm dump from another board to mine with Intel i5-1225(SPLD9)?
                  Can foreign dump damage my CPU if I didn't clear ME and TXE regions in foreign dump before programm it to the IC on the board?​
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12336
                    UX3402ZA
                    • pbls
                      • Apr 2019
                      • 12
                      • Russia
                      Thanks, hoaca388​! Can you describe - your file in attachment is dump from another board with dirty ME and TXE or maybe another one?
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12336
                        Thanks, hoaca388! Can you describe - your file in attachment is dump from another board with dirty ME and TXE or maybe another one?
                        _ME from your original file and it has been cleaned.
                        _Bios region is downloaded from ASUS homepage according to your serial number.​
                        • pbls
                          • Apr 2019
                          • 12
                          • Russia
                          Dear hoaca388, it sounds great. Thanks a lot! I will try and will post the result here.
                          • pbls
                            • Apr 2019
                            • 12
                            • Russia
                            Originally posted by hoaca388
                            UX3402ZA
                            After I programmed and soldered IC on the board - I received next messege on the laptops display - you can see it in the attachment.
                            Click image for larger version  Name:	12345.jpg Views:	0 Size:	1.27 MB ID:	3472579
                            I made all the steps from this instruction with or without battery with plugged AC Adapter, tried to use different flash drives with NTFS/exFAT partitions, but Asus Flash Utility didn/t start anyway. Where is the problem? Why laptop didn't start after BIOS programming?
                            • volinakis
                              • Jan 2021
                              • 2874
                              • N/A
                              put on USB disk only UX3402ZAAS.310 file
                              • pbls
                                • Apr 2019
                                • 12
                                • Russia
                                Already tried this way. in archive, without archive, tried different flash drives, with or without SSD on the board - no result, just the same message on the display every time.
                                • pbls
                                  • Apr 2019
                                  • 12
                                  • Russia
                                  UX3402ZA
                                  In this file I didn't find my serial number N4N0LP00W77515E
                                  Maybe problem is that one of BIOS regions isn't correct, because in my dump from the board I found the correct serial number
                                  • pbls
                                    • Apr 2019
                                    • 12
                                    • Russia
                                    I used another BIOS and it's fully worked. Laptop is fully worked. Problem was resolved. Dear, hoaca388 in your file there is a mistake somewhere.
                                    • pbls
                                      • Apr 2019
                                      • 12
                                      • Russia
                                      this one is working and tested.
                                      • washington rander
                                        • Aug 2024
                                        • 6
                                        • brazil
                                        I have a notebook with a bios problem, if anyone can help me, I will attach a copy of the original bios files
                                        brand: Asus
                                        model:ux3402z
                                        Serial number: 90nb0wc1-m012f0
                                        nan0b6024407427
                                        mdf: 2022-10
                                        motherboard code
                                        nb5936_mb_v3​
                                          ASUS ZenBook Zenbook 14 Flip OLED UN5401QA-KN144W Notebook Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook Zenbook 14 Flip OLED UN5401QA-KN144W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Zenbook 14 Flip OLED UN5401QA-KN144W boardview and Zenbook 14 Flip OLED UN5401QA-KN144W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 06:31 AM
                                          ASUS ZenBook UX8402VV-PS96T Notebook Pro 14 Duo OLED Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook UX8402VV-PS96T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX8402VV-PS96T boardview and UX8402VV-PS96T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 07:20 AM
                                          ASUS ZenBook UX7602VI-MY022X Notebook Pro 16X OLED Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook UX7602VI-MY022X Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX7602VI-MY022X boardview and UX7602VI-MY022X schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          ASUS ZenBook UX582ZW-H2004W Notebook Pro Duo 15 OLED Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook UX582ZW-H2004W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX582ZW-H2004W boardview and UX582ZW-H2004W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          ASUS ZenBook UX8402VU-P1036X Notebook Pro 14 Duo OLED Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook UX8402VU-P1036X Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX8402VU-P1036X boardview and UX8402VU-P1036X schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
