Need Help For Bios File Asus A409JB-EK502T
  • dayzcore
    • Feb 2021
    • 8
    • indonesia
    Help..!!
    Does anyone have one bios for asus A409JB-EK502T​
    Bios Dump!!
    • 21665
    You MUST:
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • notrespond
      • Apr 2024
      • 70
      • ID
      hello need rebuild old bios dump
      type : A409JB-BV321T
      SN : L7N0CX03D149288
      BOARD : X409JA R2.0
      • shiyab
        • Sep 2023
        • 1592
        • india
        BOARD : X409JA R2.0
        hi try
        • notrespond
          • Apr 2024
          • 70
          • ID
          Originally posted by shiyab
          hi try
          not work,maybe any problem board
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
          • Sebastian Codrean
            BIOS file for ASUS F542UN laptop
            by Sebastian Codrean
            Hello to all of you! I need help with a BIOS file.
            The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
            So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
            02-20-2025, 10:25 AM
          • DynaxSC
            by DynaxSC
            06-14-2024, 03:49 PM
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
          • kodox
            Asus ExpertBook B1400CB Bios Dump Needed
            by kodox
            need original bios dump, original bios has flashed by other technician before me.
            attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
            unit info:
            Model: Asus ExpertBook B1400CBA-0711A1235U
            S/N: R6NXNZ006657238
            CN: 7F6F
            Mainboard Code: B1500CBA R2.1...
            08-16-2025, 12:20 PM
