Asus G553ZW Bios dump need
  • tolga26
    • Mar 2017
    • 17
    • us
    Asus G533ZW-AS94
    SN : N5NRKD007877187
    Board id G533R-PMV-A01
    6050A3340403-MB-A01
    2021-11-26
    i need bios file pls.
    my old bios 👇
  • Userrisudtion
    • Sep 2025
    • Uzbekistan
    Hello tolga26 i have a g533zw and my winbond is die because of this i need bios dump you fiend it ?
    if you fiend it can you send me please 🙏
    • repairhi
      • Nov 2023
      • 6
      • Sweden
      ROG Strix SCAR 15 (2022) G533 - LAPTOPS - ASUS G533ZW-LN092W
      Motherboard has two bios chipsets:
      - winbond 25R256JVEN ,32MB
      - winbond 25Q16JWNIQ ,2MB
      G533R-PMV-VGT
      6050A3340404-MB-A01
      I checked Asus website : https://www.asus.com/us/supportonly/...helpdesk_bios/
      I need dump for both bios chips.
      Both laptop dumps attached as zip file.
      Problem: Laptop turn on, keyboard change color but won't boot, no logo, black screen, fans off, usb port won't work.
      Regards
      • peste
        peste commented
        Editing a comment
        post merged..
    • m1ch43lzm
      • Mar 2019
      • 2047
      • Peru
      Type the laptop serial number, full name and model, motherboard model, etc.
      Please read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
      • repairhi
        • Nov 2023
        • 6
        • Sweden
        ASUS G533ZW-LN092W
        SN: N2NRKD00490605D
        Board id :
        G533R-PMV-VGT
        6050A3340404-MB-A01
        I need dump for both bios chips. Already searched and flashed this file : https://www.badcaps.net/download/?id=57d29497
        Did not help.
        Problem is : Laptop turn on, keyboard change color but won't boot, no logo, black screen, fans off, usb port won't work.
        Additional bios related info if needed.
        • shiyab
          • Sep 2023
          • 2833
          • india
          ASUS G533ZW-LN092W
          SN: N2NRKD00490605D
          Board id :
          G533R-PMV-VGT
          6050A3340404-MB-A01
          Did not help.
          POST 32 mb
          • repairhi
            • Nov 2023
            • 6
            • Sweden
            Originally posted by shiyab
            POST 32 mb
            32 mb dump attached
            • shiyab
              • Sep 2023
              • 2833
              • india
              32 mb dump attached
              hi try
              • repairhi
                • Nov 2023
                • 6
                • Sweden
                flashed it, the same problem, keyboard keys elominate and change color but system wont boot , cold cpu and no fan.
                • shiyab
                  • Sep 2023
                  • 2833
                  • india
                  mabe bord ..ram or cpu and gpu
                  • ronaldopdias
                    ASUS ROG Strix B660-I Gaming WiFi – BIOS dump vs ASUS CAP size mismatch, need corruption check, please.
                    by ronaldopdias
                    I’m troubleshooting an ASUS ROG Strix B660-I Gaming WiFi motherboard and I’m a bit stuck at the BIOS level. What I’ve tried so far
                    • Attempted to flash the BIOS using the USB BIOS FlashBack (Q-Flash) port with a properly formatted FAT32 USB drive.
                    • BIOS file downloaded directly from the official ASUS support page.
                    • Followed the exact FlashBack procedure (correct port, renamed file, standby power only).
                    Issue:
                    The FlashBack LED does not blink at all — no activity whatsoever. Further investigation
                    Because FlashBack didn’t work, I:
                    • Removed the BIOS SPI IC from
                    02-04-2026, 03:16 AM
                  • kinojk2
                    ASUS Prime Z790-P (NON-WIFI) Bios dump and questions
                    by kinojk2
                    Hi, Thanks for all you do here.
                    I have attached my 16MB dump.
                    EDIT2: All hardware working fine, I think I just need to update my linux booatloader and all gucci
                    EDIT:
                    I can get into bios now! I reflashed as instructed elsewhere. With a minimal POST (just 1 stick of ram , GPU, CPU, no drives) I have loaded into BIOS. I am about to reinstall my other hardware components now.
                    The clips are such a pain to use, soldering would be a great skill to have.
                    Thanks for the advice in other threads!
                    To answer my own question, I didn't...
                    03-24-2026, 05:55 AM
                  • pirati
                    by pirati
                    10-27-2025, 04:20 PM
                  • razor_amd
                    by razor_amd
                    12-15-2020, 07:07 PM
                  • gandamonteiro
                    ASUS A407UB (36AM1SB1) Rev 2.0 – Full 8MB BIOS Dump Request
                    by gandamonteiro
                    Hello.
                    I am looking for a FULL 8MB BIOS dump for:
                    ASUS A407UB
                    Board: 36AM1SB1
                    Rev: 2.0
                    The laptop has no 3.3V rails after a bad BIOS flash.
                    Originally the board powered on abnormally (CPU heating as soon as adapter was plugged).
                    After flashing an incomplete BIOS image, the board is now dead (no 3.3V, no boot).
                    What was tried:
                    - Read BIOS guides and recovery methods
                    - Used official ASUS BIOS file (partial image)
                    - Tried flashing with external SPI programmer
                    - Recovery was not successful
                    Request:...
                    12-21-2025, 09:01 AM
