C22NA main board rev 2.2 bios
  • imitari digital
    • Jan 2023
    • Uganda
    looking C22NA main board rev 2.2 bios kindly
  • peste
    • 13451
    • ROMANIA
    read..
    Post the full name and model of the laptop, the S/N, the original bios even if it is corrupted, etc.
    • DynaxSC
      by DynaxSC
      11-17-2023, 10:56 AM
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
    • ygorsan
      by ygorsan
      🧩 Problem Summary:
      • I
      07-28-2025, 08:34 AM
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
    • JDC
      by JDC
      ONN 100012588
      Long answer:
      07-15-2022, 07:39 AM
