Preflash Super IO chip
  • chickenhawk88
    • May 2024
    • 86
    • US
    I was wondering if you guys know anyone that sells Super IO chip ITE IT8390-256 flashed with your specific laptop. Im debating to see if this available out there vs buying chip and programmer myself. Right now the chip plus programmer is about $60. But i still need the file that goes on chip. The laptop is RAZER BLADE 15 RZ09-0369.
  • chickenhawk88
    • May 2024
    • 86
    • US
    What files do i need to program the super IO chip ITE IT8390-256 for my Razer Blade 15 RZ09-0369?
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
    • DynaxSC
      ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
      by DynaxSC
      Hi
      I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
      08-04-2025, 12:20 PM
    • MORETTIGIAN
      by MORETTIGIAN
      Title:
      Description:
      Procedure performed:
      - Removed backplate
      - Reapplied thermal compound
      - Reassembled card
      09-18-2025, 12:14 PM
    • ongobongo
      Asus ROG Ally - Super IO Chip replacement
      by ongobongo
      anyone here who has experience with replacing the super IO chip of an ROG ally?
      I have one on my bench which has a burnt super io (ITE 5125VG-192). On some devices the super-io downloads it's firmware from BIOS if it's empty. As i don't have a programmer for this chips i hope someone here has already changed the chip and can give me a hint if it's working with an empty chip if it needs external programming.
      Ongo
      11-17-2024, 11:27 AM
      Common SPI bios chip programming Questions and Answers
      by SMDFlea
      Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
      A: If you can`t read from it how do you expect to write to it ?.
      Q: Why is my bios chip unreadable ?.
      A: The programmer is faulty or has a worn or broken zif socket.
      The USB cable is frayed,connector pins worn or some other physical damage.
      Not enough amperage or voltage to power the programmer properly.
      Bad...
      09-02-2021, 04:40 PM
