BIOS for Asus ROG G713PV
  • steveoski
    • Feb 2016
    • 22
    Hey guys looking for the Bios for an Asus ROG G713PV-DS94
    Motherboard Number is g713p-mb-VGT 6050A3468901-MB-A01
    Serial Number is R3NRKD03613412E
    i am not sure if any additonal information is needed if so let me know and i can update this post. Things i have tried are to download the BIOS directly from Asus but that file is a .329 file and is 32MB as opposed to the 16MB file i need. Scoured high and low and cant find this darn BIOS anywhere! Much appreciated!!
    • 21672
    If you have a backup post it .
    • steveoski
      • Feb 2016
      • 22
      Here is the BIOS backup Thanks in advance!
      • hoaca388
        Badcaps
        • Jan 2022
        • 12268
        Name of your bios chip ? Searching by your serial number only has a 32MB file. Replace the chip you have with a 32MB chip and then flash a new bios.
          • 21672
          What you`ve backed up seems to be the TPM firmware, it isn`t the bios.Look for another chip
          • steveoski
            • Feb 2016
            • 22
            Ok there is only 2 chips on the motherboard that resemble BIOS chips one is a Winbond W25Q80DV which i will add the dump to this thread and the other is an MXIC MX77U25650FZ4142 and that is the chip i posted the dump for on the original post. I cannot find the schematic for this board online anywhere so i can only inspect the board under my microscope and look for chips resembling BIOS chips. I can post pictures of both sides of the board if that would be helpful. I am attacvhing the dump from the WINBOND chip to this post
            • steveoski
              • Feb 2016
              • 22
              The name of the chip i believe to be the BIOS chip is an MXIC MX77U25650FZ4142
              • steveoski
                • Feb 2016
                • 22
                One other question the BIOS chip is not listed in the list at all in asprogrammer so i chose a different chip and then read the firmware and posted it. The chip i used was 16mb and i think this BIOS is 32mb as previously stated. Would that throw off the dump if the incorrect chip size is not selected? I have successfully flashed many BIOS but i am not an expert by any means i am here to learn and do appreciate any and all help Not sure how to enter the chip manually into the programmer or what to do in a situation when the chip is not in the programmer list.
                  • 21672
                  Try NeoProgrammer software. Choose a 25Q256 1.8V chip .I think its 1.8V but not sure. You do have to choose a chip thats the same size.
                  • steveoski
                    • Feb 2016
                    • 22
                    Ok i will download that and see what happens. The 25q256 does show up in asprogrammer but i think the problem is that i made a backup of the bios with the wrong chip selected as i chose one that was 16mb so the dump i provided here is incomplete as it would be missing 16mb of data. Since then i have tried writing a few different BIOS files to this chip to see if they work. So i no longer have a backup of the original bios. I am not sure how to make a new one from the BIOS that is available for download at ASUS support. Is there any hope? i have not seen a single post anywhere for this particular model and or board revision. The other BIOS for other laptops i have successfully flashed i have been able to find them on various threads on this forum for different laptops and they have all worked. This machine is pretty new so there isn't much out there in terms of schematics bios etc. Thanks for your help thus far
                    • luzvel64
                      • Apr 2017
                      • 103
                      • Guatemala
                      Greetings friends,
                      I am looking for help with the bios Asus ROG G713PV-DS94 does not give video after a bios update,
                      I am attaching my backup.
                      The motherboard is:
                      G713P-MP-VGT
                      6050A3468901-MB-A01
                      2022-12-02​
                    • luzvel64
                      • Apr 2017
                      • 103
                      • Guatemala
                      Originally posted by luzvel64
                      Greetings friends,
                      The motherboard is:
                      G713P-MP-VGT
                      6050A3468901-MB-A01
                      2022-12-02​
                      S/N: R9NRKD03502437C
                      MANY THANKS
                      • luzvel64
                        • Apr 2017
                        • 103
                        • Guatemala
                        Hi, I solve it,
                        I leave the file used in case it helps someone.
                        • steveoski
                          • Feb 2016
                          • 22
                          Hi, I solve it,
                          Confirmed this works for me as well! Thanks a million really appreciate that!!
                          • kazttiyo
                            • Jun 2015
                            • 11
                            • Chiapas
                            Hi, I solve it,
                            Hello, thank you very much, the dump worked for me. Greetings. 👍
                            • lavie
                              • Aug 2015
                              • 90
                              • southafrica
                              greetings family please can someone help me fix this asus no display motherboard part number 6050A3468901
                              asus G713PV. as for the serial number there is no sticker on the back . please help help
                              • shiyab
                                • Sep 2023
                                • 1592
                                • india
                                • danito
                                  • Jun 2016
                                  • 1068
                                  Try
                                  • lavie
                                    • Aug 2015
                                    • 90
                                    • southafrica
                                    Originally posted by danito
                                    Try
                                    thanks bro still no display
                                    • lavie
                                      • Aug 2015
                                      • 90
                                      • southafrica
                                      HVE GOTTEN THE SERIAL NUMBER R3NRKD007389129
                                      • Sebastian Codrean
                                        BIOS file for ASUS F542UN laptop
                                        by Sebastian Codrean
                                        Hello to all of you! I need help with a BIOS file.
                                        The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                                        So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                                        02-20-2025, 10:25 AM
                                      • jbonavita
                                        by jbonavita
                                        Some issues
                                        Things I tried
                                        04-29-2025, 09:38 PM
                                      • caglarec2268
                                        Asus X515EA Bios File Please
                                        by caglarec2268
                                        merhaba dizüstü bilgisayarım windows ile bios update yaparken kapandı.
                                        Now "please follow the steps below to recover your bios" text remains on the screen
                                        I tried backup bios files from the site but the keyboard did not work properly or the ssd did not read the disk. Can my bios be repaired? Or is there a correct active bios? please help thank you.
                                        laptop model x515ea-bq945w
                                        s/n: R4N0CV02K527148
                                        CN:HWFB
                                        Board model; ASUS X415EA R7.0
                                        bios chip: GD25Q128...
                                        11-27-2024, 03:51 AM
                                      • Citymin
                                        by Citymin
                                        S/N : 5RNK9FFT70...
                                        08-05-2025, 05:12 AM
                                      • wakethesleep1111
                                        Bios File Needed for asus tuf15
                                        by wakethesleep1111
                                        Hi im new and I have a question. I am in need of a bios file to flash my bios with preferably without the bios password included. I have a Tuf f15 gaming laptop. The model is a TUF506L. The bios chip is a Winbond W25Q128JV. The size is 16777216.
                                        05-27-2025, 10:56 PM
