DA0G7FMBAG0 Rev: G
  • JTEK
    • Feb 2018
    • 48
    • Philippines
    DA0G7FMBAG0 Rev: G
    HP Pavilion 13-bb0503TU (i3-1125G4)
    Board #: DA0G7FMBAG0 Rev: G
    SN#: 5CD15165HF
    ISSUE: Laptop is No power and no charging light indicator with a current of 124mAh, I replaced the SIO (IT5570VG) and the charging light indicator is now ok while the current is normal but still No power when I press the power button maybe this is a bios issue so attached my dump file if anyone can fix it for me? I appreciate any help from u guy's thanks
  • danito
    • Jun 2016
    • 980
    • Romania
    SN#: 5CD15165HF
    Try
    • Ernesto Flores
      • Sep 2024
      • Chile
      I know it's been a while, but ask, how did you program the IT5570VG-256, what did you change?
      • rounin
        MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
        by rounin
        🛠 Original Issue
        ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
        04-19-2025, 01:18 AM
      • ugamazing
        by ugamazing
        12-17-2024, 07:05 PM
      • ahmarzo
        Acer laptop battery draining issue
        by ahmarzo
        Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
        Help me to diagnose this issue as there is no shortage in the inputs MOSFET
        08-02-2025, 06:39 AM
      • elmark
        HP 15-cw1002ua strange keyboard issue
        by elmark
        HP Pavilion 15-CW1002UA
        S/N 5CD0251CBC
        P/N 7KE54EA
        Hello guys!
        I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
        It powers on OK and has no other issues except the following:
        • CAPS LOCK does not work at all
        • Fn button toggles Flight Mode
        • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
        • (with SHIFT pressed: 't%' and 'y^' respectively)
        I initially thought it was a keyboard malfunction (internal short, etc.),
        but when I press and hold...
        06-27-2025, 01:10 AM
      • Simone Vergani
        Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
        by Simone Vergani
        I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
        To assist with troubleshooting, I'm attaching two power circuit schematics:
        • Power
        03-05-2025, 02:25 PM
