820-00165
  • bargo
    • Aug 2022
    • 46
    I used this 1466 bios specifically for my mainboard, the previous serial number had only three or four differences
    Replace XXXXX serial number with your serial number.
  • bargo
    • Aug 2022
    • 46
    This version above is not recommened, the ME region is not very clear and causes a slow chime and other bad stuff. But at least I managed to get my mainboard to trun for the first time using it, now I will post a better version soon
    • bruce35
      HP 600 G3 MT serial number change please
      by bruce35
      HP 600 G3 MT
      SERIAL NUMBER MXL8301K1C Serial number in the file in bios
      SERIAL NUMBER CZC72988BY original serial number of the safe original serial number of the safe
      Thank you very much...
      09-24-2025, 02:32 AM
    • Mirenia
      Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
      by Mirenia
      I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
      I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
      In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
      The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
      03-30-2025, 06:47 AM
    • orcic
      MASTER TL240 and new mainboard LW36BKC01
      by orcic
      I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
      The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
      After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
      Now I have some doubts about how to connect the new mainboard to the old power supply.
      First of...
      05-12-2023, 08:10 AM
    • Dannyx
      UART (serial ?) splitter ?
      by Dannyx
      Good day folks. I got a project on hand and would like some thoughts on whether it's possible to achieve, albeit impractical. You know me - I like to over-complicate stuff
      The setup: I got a Paradox EVO192 alarm panel, a serial-to-ethernet adapter and an official PCS250 GSM communicator.
      The task (TL/DR): connecting both the ethernet adapter AND the communicator to the single serial port of the Paradox panel. Connecting their TX/RX lines in parallel the data would get all messed up. At the very most, I THINK I could parallel the RX pins of the ethernet adapter...
      08-18-2023, 03:21 PM
    • mshone
      Lenovo thinkpad P1 G2 UUID and Serial number/mashine type unknown
      by mshone
      Sorry if topic if misplaced. Have lenovo thinkpad P1 gen2 with Xeon E-2276M CPU and NVIDIA® Quadro® T1000. It is a new board replaced. Old board was P1 G1 model with i7 and it is defective. I ordered a new one with xeon, but is gen 2. Laptop case is suitable for this motherboard, with some little difference (GPU fan and subcard).Ok, ordered and replaced and GPU fan and subcard and now laptop is working fine, but serial number and UUID is unknown. Ok, i readed several topics here and found Thinkpad maintenance disk, but.....which values to type? How to find data base with those values? serial...
      08-29-2025, 06:41 AM
