HP EliteBook 835 G7 Bios Request
  • max_sneka2
    • Mar 2022
    • 81
    • iraq
    Good evening Everyone
    I need Bios Bin File For Hp elitebook 835 G7
    Board Number LINDEN 6050A3147201-MB-A01 (A1)
    Here is Old Bios File
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Read the rules before posting
    You MUST:
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • Name your thread with make, full model numbers and request
    • Provide a BIOS/EC dump if possible
    • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
    Become a Badcaps supporter
    Thanks to all supporters.
    • max_sneka2
      • Mar 2022
      • 81
      • iraq
      You MUST:
      Bios Issue . Black Screen . Turned Off after failed update of bios
      S.N 5CG0330FLM
      • barbarian2009
        • Nov 2022
        • 6
        • Ukraine
        Board Number: LINDEN 6050A3147201-MB-A01 (A1)
        ProdID: 8RN38AV
        SN# 5CG1271K42
        Build ID: 20WWLDDT601#SAK8#DAK8
        I tried to remove the password, read BIOS with CH341A (3.3V fix) programmer. BIOS was read in NeoProgrammer 2.2.0.10. Dump data was read and checked 4 times (compared in HxD). Deleted data area 37000 to 37820 via Hxd. Flashing. At power on, the power LED is on and caps lock flickers 7 times. Flashed back dump BIOS and still the laptop does not turn on. I think the dump is corrupted. Please see how bad it is. (Pardon my English)
        • barbarian2009
          barbarian2009 commented
          Editing a comment
          Originally posted by danito
          try
          Thank you. I tried that but it didn't work. At first it tried to turn on (even the fan was spinning) but then caps lock started flickering again and won't turn on.
      • danito
        • Jun 2016
        • 842
        • Romania
        ProdID: 8RN38AV
        SN# 5CG1271K42
        try
        • barbarian2009
          • Nov 2022
          • 6
          • Ukraine
          try
          Deleted the first byte from your file and the laptop turned on. Thank you.
          • barbarian2009
            • Nov 2022
            • 6
            • Ukraine
            That didn't fix the problem. Now the notebook does not turn on the first time. It says: Final step of BIOS update. Then it reboots and flickers caps lock 7 times. Several times I managed to boot into Windows and flash SN, PCID, CTNumber, FeatureByte, BuildID via BCU. If you turn off and disconnect the RTC battery for a while and then reconnect it again, it may turn on. Is this a problem with the firmware in the second chip?
            • barbarian2009
              • Nov 2022
              • 6
              • Ukraine
              Finally solved the problem.
              What I did:
              1. Completely cleaned the second BIOS chip. And soldered it in place (without writing anything into it)
              2. In the main BIOS chip flashed the files that threw “danito” (In them BIOS built from the update on the official site HP).
              3. Main BIOS chip soldered on the board.
              4. Check the soldering! Everything is soldered.
              5. Via BIOS Configuration Utility flash SN, PCID, CTNumber, FeatureByte, BuildID
              Done. No more passwords and no more Security Endpoint controller Problem errors.
              • spawnx212484
                • Jan 2017
                • 9
                • france
                S.N 5CG0330FLM
                Hi, have you found a solution? I've had two PCs in a week with corrupted bios...
                • batuhanca
                  • Jun 2019
                  • 14
                  • türkiye
                  If you want, try these as well.
                  • spawnx212484
                    • Jan 2017
                    • 9
                    • france
                    Perfect, it works, but when the computer starts up I get "manufacturing programming mode", is that a problem? don't I have info to recover from the dead bios?
                    • danish8717
                      • Dec 2021
                      • 21
                      • united arab emirates
                      hp 835 g7
                      serial no 5CG11551MC
                      sound not working
                      • tcccorp
                        • Jan 2025
                        • 3
                        • France
                        hello,
                        I read there is 2 flashs on this laptop but I'm just able to find one, near nvme ssd. Could you say me where is the second one ?
                        thanks
                        • peste
                          • Dec 2016
                          • 12254
                          • ROMANIA
                          Originally posted by tcccorp
                          hello,
                          thanks
                          search both sides..
                          • tcccorp
                            • Jan 2025
                            • 3
                            • France
                            hello Peste,
                            Thanks, i checked other side and i found another flash, TPM and security chip !
                            • sergg_zp
                              • Apr 2025
                              • Ukraine
                              HI,
                              HP Eleitebook 835 G7
                              Part Number - 8RN39AV
                              Serial Number - 5CG1204DYT
                              Caps lock blinking 7 times. Please help.
                            • jbonavita
                              by jbonavita
                              Some issues
                              Things I tried
                              04-29-2025, 09:38 PM
                            • zenius
                              by zenius
                              12-08-2024, 06:13 AM
                            • 247
                              [Request] BIOS file for Medion Akoya S6445 (MD61280)
                              by 247
                              I'm looking for the original BIOS file for the Medion Akoya S6445 – model MD61280, preferably in .bin or .rom format for flashing via CH341A programmer.
                              The BIOS chip is a GStek GS7166 (25Q64 compatible, 8MB SPI).
                              Does anyone have the correct BIOS file or know where to get it?
                              Any help would be greatly appreciated!
                              Thanks!
                              04-08-2025, 11:08 AM
                            • maanee11
                              Request for Lenovo 5-15IMH05H Type 81Y6 BIOS bin file
                              by maanee11
                              Hello Everyone,
                              I have Lenovo Legion 5-15IMH05H (Lenovo) - Type 81Y6
                              and I have encountered a Black screen on startup. I have tried the power drain and all sorts of tricks that were available online to revive it but no joy.
                              Since I have already an expired warranty, I am thinking of flashing the BIOS externally. I have a Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, I need a bin file for the BIOS. The latest BIOS executable can be found here but I need the bin file to flash it externally.
                              https://p...
                              12-06-2022, 02:15 AM
                            • Forest79
                              by Forest79
                              However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                              07-23-2023, 07:39 AM
