Microsoft Surface Pro 9 2083 Unlock Bios
  • ALeXXBodyz
    • Aug 2019
    • 10
    • United Kingdom
    #41
    Originally posted by Bios Cracker
    If you wanna learn about the process...some info is available in this video. You need to follow the process.
    https://youtu.be/nxM7kBAJ5tc?si=7d9sNYhcZG6slUV9
    Tested something similar but it didn't work. With your file, the unit is showing logo for 7-8 sec. and turns off, than logo again and off
    • Bios Cracker
      • Oct 2024
      • 322
      • India
      #42
      Read properly i did'nt tell you to flash the bios...it is fixed to get decomposed in MFIT where you got the error of MFS failed to initialize. Rest after decomp you can do it yourself.
      • ALeXXBodyz
        • Aug 2019
        • 10
        • United Kingdom
        #43
        Ok. Thank you
        • Zeeshanali1
          • Oct 2018
          • 27
          • Pakistan
          #44
          SURFACE PRO 9 2038
          HELP ME FIX SURFACE PRO 9 HANG ON LOGO
          SN== 0F01B4Z22523BF​
          zash
          • hoaca388
            Badcaps
            • Jan 2022
            • 12330
            #45
            Originally posted by Zeeshanali1
            SURFACE PRO 9 2038
            Try
            ​https://www.badcaps.net/donate
            • Zeeshanali1
              • Oct 2018
              • 27
              • Pakistan
              #46
              Originally posted by hoaca388
              Try
              THANKS FOR HELP BUT LAPTOP HAS SAME PROBLEM
              zash
              • Bios Cracker
                • Oct 2024
                • 322
                • India
                #47
                SURFACE PRO 9 2038
                Try and Update.
                • uvaiz
                  • Jan 2014
                  • 113
                  • saudi arabia
                  #48
                  PLEASE REMOVE BIOS PASSWORD
                  MODEL SURFACE PRO 9
                  THANKS
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12330
                    #49
                    MODEL SURFACE PRO 9
                    THANKS
                    REMOVED BIOS PASSWORD
                    • payam
                      • Nov 2015
                      • 79
                      • iran
                      #50
                      Hello, can someone please help me? My surface pro 9 2038 is stuck on the logo. This is the device serial number
                      sn: 0F00E9322393BF
                      • Karol
                        • May 2016
                        • 90
                        • Romania
                        #51
                        sn: 0F00E9322393BF
                        BRAND : Microsoft Corporation
                        MODEL : Surface Pro 9 for Business 2038
                        SERIAL : 0F00E9322393BF
                        BIOS VENDOR : Unknown
                        ENROLLMENT : NO SIGNATURE FOUND
                        ME VERSION : 16.1.25.1932 (Not in MEA.dat)
                        Joe's KMX1 Pro S, RevelprogIS, TL866II, CH341A, Vertyanov JIG 3.1, Eakins Microscope, Gordak 952, 30V/5Ah PSU, 890C+, T2L Thermal Camera, SVOD 3, etc.
                          SMDFlea commented
                          Editing a comment
                          Post rdited. Don`t post windows keys please !
                      • payam
                        • Nov 2015
                        • 79
                        • iran
                        #52
                        Thank you very much, but the Lego image keeps resetting every 2 seconds.
                        • payam
                          • Nov 2015
                          • 79
                          • iran
                          #53
                          Please, can anyone help me ?
                          • denlok
                            • Nov 2016
                            • Ru
                            #54
                            Hello Bios Cracker
                            "Try and Update."
                            What you means under "update" ?
                            I have a Surface Pro 9 2038 v16.1.32.2418 with loop on Logo. Very carefully readed the BadCaps threads, saw the video tutorial by your link, followed your steps.
                            But unfortunately, can't run my tablet properly.
                            The SP9 come to me by eBay with Logo loop every 10sec. I see it is often problem after update of firmware to version 16.1.32.2418.
                            I see, the CPU on motherboard is cold, does not starts when logo is flashing.
                            I readed the Chip W25Q256, found the MEAnalyzer r366, found the Mfit 16.1.25.2091.
                            The source dump loaded to MFIT shows error Details: 'Error occurred while trying to create container CseRegion. Reason: StorageLib error. Function "meMfsMfitInit" execution failed. Error details: Failed to initialize MFS.'
                            With MEAnalyzer I see the CSE ME version 16.1.32.2418, "ADP-LP A" "Initialized", Size 0x4C0000
                            Then I try to clean ME: found the file intel_me_16.1.32.2418-LP(station-drivers.com).zip, extracted by this binary the regions MFS and EFS - they are not initialized in this file.
                            Then injected these 2 binaries to my source laptop binary as shown on your video.
                            After that, the MFIT shows me green "OK" with my modified binary, the MEAnalyzer shows me "Configured" also.
                            But, after writing this modified dump to chip, I see now a small changes: No BootLoop but Stuck with Logo. The CPU starts working because hot, and nothing more.
                            "Try and Update." - What you means under "update" ?​
                            Can you please check my files, maybe I do something not well?
                            Thanks before
                            Model: Surface Pro 9 2038
                            S/N 0F01LU923363BF
                            • souaqi01
                              • Dec 2015
                              • 87
                              • Maroc
                              #55
                              any one help plz for removing password surface pro 9
                              SN: BK33JGB24053BF
                              • shiyab
                                • Sep 2023
                                • 1608
                                • india
                                #56
                                SN: BK33JGB24053BF
                                hi try
                                • souaqi01
                                  • Dec 2015
                                  • 87
                                  • Maroc
                                  #57
                                  hi any one remove the password surface pro 9
                                  SN:0F020VR222400E
                                  • souaqi01
                                    • Dec 2015
                                    • 87
                                    • Maroc
                                    #58
                                    Originally posted by shiyab
                                    hi try
                                    thanks bro
                                    • Loki_Fido
                                      • Mar 2025
                                      • 127
                                      • Japan
                                      #59
                                      Hi folks,
                                      My Surface Pro 9 keeps booting into BIOS.
                                      I tried with different hard disk and no change.
                                      I formatted the hard disk and tried to freshly install the Win 11 but, the surface wont boot into USB drive. I even tried to boot from Win-To-Go USB drive. No use.
                                      So i did what everyone would expect me to; download a BIOS from BadCaps and load into it. That didn't work either.
                                      I properly unsoldered the BIOS chip and soldered it to the CH341A. Re-verified it multiple times.
                                      I went to the Microsoft website to download the original firmware and OS.
                                      But this tablet wont boot anything from USB drive.
                                      At this point i am out of ideas.
                                      Attached is my original bios backup.
                                      Surface Pro 9
                                      Model 2038
                                      SN 0F01SPY23053BF
                                      I am hoping somehow this is still bios issue.
                                      Can someone please help me fix this issue. If it happens to be a hardware issue, please advice me. I have all the tools.
                                      Love you all.
                                      Edit:
                                      I dont know how to clean ME. Therefore I didnt. Can that be the issue? Any thoughts?
                                      • Loki_Fido
                                        • Mar 2025
                                        • 127
                                        • Japan
                                        #60
                                        Hi ya folks,
                                        Remember everyone, especially next person to upload a BIOS for Surface Pro 9, be sure to mention whether the BIOS is from an Intel powered Surface Pro 9 or Microsoft's Pro 9
                                        Because there are 2 types of processor powering the surface.
                                        Easy to tell which is powering yours.
                                        If there's sim card slot, then its 5G and Microsoft's processor with ARM structure
                                        No SIM slot means Intel's x64
                                        Be sure to mention folks, so others in future wont mistake and use the wrong BIOS.
                                        Thanks.
                                        Happy repairs
