Latitude 7420 - BIOS repair possible?
  • Mirenia
    • Jan 2024
    • 53
    I finally got managed to desolder my BIOS-Chip and create a dump.
    My Latitude 7420 won't post, but keyboard-backlight and fans are on.
    Mainboard: GDC31 LA-K371P Rev:3.0(A02)
    BIOS-Chip: Winbond w25r256jv
    Service-Tag: 9SWP2J3
    Can you please have a look at it and maybe fix it?
  • qayyum786
    • Aug 2018
    • 1959
    • INDIA
    do you have image on external monitor/tv via HDMI or on USB KEYBOARD CAPS LOCK LIGHT BLINK when you press caps lock on keyboard
    • Mirenia
      • Jan 2024
      • 53
      Nope, no image on external monitor. Capslock on internal keyboard lights up permanently. External Keyboard is not recognized.
      I already tried flashing BIOS with a bootable USB-Stick (solution from Dell support page) and NVRAM-Reset. But nothing works
      • Vesko356
        Vesko356 commented
        Editing a comment
        It's under highest Dell support service plan "Pro Support Plus" until 26 SEPT 2024. It's best to contact the manufacturer first for a warranty repair before you've made things worse by trying to do it yourself.
    • qayyum786
      • Aug 2018
      • 1959
      • INDIA
      your posted bios is 65 mb it should be 32 mb only
      Read and post again
      • Mirenia
        • Jan 2024
        • 53
        Yes, I also suspected that my BIOS file is much too large.
        But it is exactly what I read out of the chip using the programmer.
        So is this maybe a mistake of my programmer or is something really wrong with my BIOS?
      • Mirenia
        • Jan 2024
        • 53
        Vesko356 The Laptop was gifted to me. So I had no proof of ownership and unfortunately no longer contact to the gifter.
        Do you think I can try to contact the support despite it?​
        • Vesko356
          Vesko356 commented
          Editing a comment
          Yes of course. At least try, it's possible they won't ask you for any papers, besides the warranty support level is highest possible as I said, and the location of the warranty is exactly in Germany.
      • hoaca388
        Badcaps
        • Jan 2022
        • 12333
        Read and post again
        His bios is repeated at bit 2000000h.
        • qayyum786
          • Aug 2018
          • 1959
          • INDIA
          yes you are right i got it
          • qayyum786
            • Aug 2018
            • 1959
            • INDIA
            Try
            • Mirenia
              • Jan 2024
              • 53
              Thanks a lot!!!!
              I flashed the chip with your file and soldered it back onto the board.
              But now the laptop seems completely dead. Only the LED lights up in red as long as I press the power button.
              No charging and no reaction.
              Maybe I shorted/damaged something while soldering (I will check this tomorrow)
              P.S: I am a she and not a he
              • devp62
                • 57
                My Latitude 7420 won't post, but keyboard-backlight and fans are on, power led is white and stays white no flash codes, was working until it did a bios update and hasn't come back up.
                Can some one please help me clean the file. Thanks
                Mainboard model no is GDC31 LA-K371P Rev:3.0(A02)
                BIOS-Chip is a Winbond w25r256jv
                Service-Tag: J2JRCB3​
                • rex98
                  • Feb 2023
                  • 1293
                  • Mandaue CEBU, Philippines
                  here use this
                  • devp62
                    • 57
                    Thanks Rex98 all up and running again
                    • devp62
                      • 57
                      Dell Latitude 7420 won't post, but keyboard-backlight and fans are on, power led is white and stays white 3amber and 6 white flash codes, was working until it did a bios update and hasn't come back up. 2 were given to me but both in same state semi power up but no display.
                      Can some one please help me clean the file. Thanks​
                      Service-Tag: 57QT9K3
                      • devp62
                        • 57
                        Hi I tried but get the following errors and have done several reads from the chip and they are all the same size byte by byte.
                        Any Suggestion or help please, have looked on line and cant find any solutions.
                        errors:
                        Error: BPDT partition SMIP (0x34A43F - 0x4E943F) overlaps with Unknown (0x34A440 - 0x4FB440)
                        Error: BPDT partition SMIP (0x34A43F - 0x4E943F) overlaps with SMIP (0x34A441 - 0x50B441)
                        Error: BPDT partition SMIP (0x34A43F - 0x4E943F) overlaps with SMIP (0x34A448 - 0x55B448)
                        Error: BPDT partition SMIP (0x34A43F - 0x4E943F) overlaps with RBEP (0x482000 - 0x49A000)
                        Error: BPDT partition SMIP (0x34A43F - 0x4E943F) overlaps with FTPR (0x4DA000 - 0x61F000)
                        Error: BPDT partition SMIP (0x34A43F - 0x4E943F) overlaps with PMCP (0x49A000 - 0x4DA000)
                        Error: BPDT partition Unknown (0x34A440 - 0x4FB440) overlaps with SMIP (0x34A441 - 0x50B441)
                        Error: BPDT partition Unknown (0x34A440 - 0x4FB440) overlaps with SMIP (0x34A448 - 0x55B448)
                        Error: BPDT partition Unknown (0x34A440 - 0x4FB440) overlaps with RBEP (0x482000 - 0x49A000)
                        Error: BPDT partition Unknown (0x34A440 - 0x4FB440) overlaps with FTPR (0x4DA000 - 0x61F000)
                        Error: BPDT partition Unknown (0x34A440 - 0x4FB440) overlaps with PMCP (0x49A000 - 0x4DA000)
                        Error: BPDT partition SMIP (0x34A441 - 0x50B441) overlaps with SMIP (0x34A448 - 0x55B448)
                        Error: BPDT partition SMIP (0x34A441 - 0x50B441) overlaps with RBEP (0x482000 - 0x49A000)
                        Error: BPDT partition SMIP (0x34A441 - 0x50B441) overlaps with FTPR (0x4DA000 - 0x61F000)
                        Error: BPDT partition SMIP (0x34A441 - 0x50B441) overlaps with PMCP (0x49A000 - 0x4DA000)
                        Error: BPDT partition SMIP (0x34A448 - 0x55B448) overlaps with RBEP (0x482000 - 0x49A000)
                        Error: BPDT partition SMIP (0x34A448 - 0x55B448) overlaps with FTPR (0x4DA000 - 0x61F000)
                        Error: BPDT partition SMIP (0x34A448 - 0x55B448) overlaps with PMCP (0x49A000 - 0x4DA000)
                        Error: Skipped EFS partition at 0x464FF0, unrecognizable format!
                        Warning: Could not find any File System Platform, assuming 0x01 (ICP)!
                        Warning: Could not find any File System Dictionary, assuming 0x0A!
                        Warning: Data in Engine/Graphics region padding, possible data corruption!
                        Note: Multiple (4) Intel Flash Partition Tables detected!​
                        • rex98
                          • Feb 2023
                          • 1293
                          try flash my post # 12​
                          • devp62
                            • 57
                            Hi Rex98 that brings the machine to life but it won’t recognise the ssd and flashes 2 amber and 8 white leds. This was a working machine prior to the failed bios update. Any suggestions
                            • malangg
                              • Sep 2014
                              • 34
                              • United Kingdom
                              hi Rex98, can you please fix this dump.
                              symtoms
                              1-laptop does not turn on with this original bios.
                              2-service tag is : 7QRTLN3
                              thanks in advance
                              • rex98
                                • Feb 2023
                                • 1293
                                symtoms
                                thanks in advance
                                try post #12
                                • malangg
                                  • Sep 2014
                                  • 34
                                  • United Kingdom
                                  Originally posted by rex98
                                  try post #12
                                  Already tried, but laptop turned on, worked, after restarting, dead now.. not coming on..
                                  • Jeff'sTech
                                    Dell Latitude 7420 BIOS Unlock Gone Wrong
                                    by Jeff'sTech
                                    Hello everyone.
                                    I have come here with a rather specific question. I was given a Dell Latitude 7420 laptop with a busted screen, and wanted to see if I could refurbish it into my daily driver. I wanted to experiment and see if a 2-in-1 display would work as the chassis of the laptop and 2-in-1 7420 looked identical. I threw in the display and my hypothesis was correct, however, I was greeted with a locked BIOS and since I didn't know the password, I figured I'd try to unlock it somehow. I bought one of those POGO pin probe things for my CH341A programmer so I could read and make...
                                    11-08-2023, 03:30 PM
                                  • Sathsul
                                    Dell Latitude 5431 issues with dumping bios
                                    by Sathsul
                                    So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                                    The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                                    However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                                    10-28-2025, 07:49 AM
                                  • Julian Bailey
                                    BIOS update wont complete - Dell Latitude 7420
                                    by Julian Bailey
                                    Hi all
                                    Anyone come across this issue where a BIOS flash will only part complete?
                                    It will update the system BIOS and Primary EC BIOS fine but fails to update the Intel TBT Retimer, Intel TBT Retimer 2 and ME Firmware.
                                    NVMe m.2 drive isnt detected in the BIOS, but you can get into the BIOS fine and it all works in there as intended.
                                    The drive works fine in another laptop.
                                    Link to a video I made of what its doing here:
                                    Any ideas on how to overcome this?
                                    Cheers...
                                    06-02-2025, 01:39 PM
                                  • TripTop
                                    Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
                                    by TripTop
                                    Hi
                                    i have dell latitude E7270 with following symptoms:
                                    - takes long time to restart.
                                    - sometimes powers on and then off
                                    - sometimes while working it just dies,
                                    From googling online bios clean could possible resolve this?
                                    i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
                                    As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
                                    I reinstall...
                                    09-09-2024, 02:05 PM
                                  • macabook
                                    by macabook
                                    🧩 Initial Issue
                                    07-24-2025, 02:17 PM
