Lenovo Carbon X1 9th Gen bios
  • lamo
    • Nov 2017
    • 40
    • Ukraine
    Hello. Customer tried to update BIOS via Lenovo software. Update has been failed and unit was dead completely. I found working BIOS dump and flashed it. Now unit turns on very slowly, and, after every booting it tries to recover ME firmware and fails everytime. Also, unit can't detect nvme disk, so i can't boot windows to flash ME with Lenovo software. Can someone provide to me 100% working dump? There're 2 flash IC's: U49 and U801. I flashed only U49. Thanks in advance.
    • 21145
    RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
    You MUST:
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • Provide a BIOS/EC dump if possible
    • Attach files directly to your post instead of linking to external websites
    • norman@phantomtec.co.za
      • May 2021
      • South Africa
      Failed reading the ME firmware.
      2100etection error on storage device (M.2)
      Lenovo ThinkPad X1 Carbon 9th Gen
      SN:MJ-0G6Y3G
      Type:20XW-00FSUS
      This is the original extracted BIOS. I think i need the ME Region Cleaned.
      Thank You
        SMDFlea commented
        Editing a comment
        Thread merged
      • May 2021
      • South Africa
      • fredo
        • Aug 2016
        • 77
        • syria
        Lenovo ThinkPad X1 Carbon 9th-Gen
        model 20xxs3la1m
        s/n : PF3VJTBQ
        nm-d341 rev 1,0
        Please help me fix the bios. There is no image​
        • peste
          peste commented
          Editing a comment
          merged thread..
      • hoaca388
        Badcaps
        • Jan 2022
        • 11883
        model 20xxs3la1m
        s/n : PF3VJTBQ
        nm-d341 rev 1,0
        X1 Carbon 9th Generation Laptop (ThinkPad) - Type 20XX​
        Last edited by SMDFlea; 07-02-2024, 03:49 AM. Reason: X1 Carbon 9th Generation Laptop (ThinkPad) - Type 20XX
        • fredo
          • Aug 2016
          • 77
          • syria
          Thank you it works well
          • EthanMai
            • Jul 2020
            • 103
            • 美国
            LENOVO THINKPAD X1 Carbon 9th Gen
            (Type 20XW)
            ST : PF-307LWE
            The firmware is damaged, please help to repair it. Thank you!
            • EthanMai
              • Jul 2020
              • 103
              • 美国
              (Type 20XW)
              ST : PF-2TA4EX
              Slow startup, needs cleaning.Thanks.​
              • BIGGATOE
                • Dec 2024
                Hi there, firstly, this site is amazing and so glad I found it, I was lucky enough to recover some devices from a friends old garage clear out, one of them was a X1 Carbon 9th Gen, it was working great until I connected it to the internet and then it froze, it has computrace/absolute protection on it and i do not know the bios password either, if you could let me know how I can get this sorted that would be greatly appreciated! Details are as follows:
                Serial Number: PF-3NGLSN
                Type Number: 20XW-CT01WW
                Assuming you have the correct file to flash the bios, can you recommend what gadget I need to get that done? Im in the UK and have found this on amazon:
                https://www.amazon.co.uk/KeeYees-SOI...1&sr=8-1-fkmr0
                let me know if thats a good tool, thanks in advance!!
                • FeerBaron
                  • Sep 2018
                  • 39
                  Any tool will do it. Cheap CH programmer or raspberry pi. I recommend the bios clip mainly to not have to desolder.
                  Imo, this thread is very helpful to me. I hardware read the bios and it looks like this guy's:Instead I'm used to dump looking like this:
                  So now I look for versions like the latter and it's 1.68(N32ET92W) maybe if I downgrade to that version my rom becomes normal and not weird like this:
                  Not super hopeful though because his post is on 1/19/2024 and that date already AFTER this bios is released.
                  • BIGGATOE
                    • Dec 2024
                    Hi FeerBaron, unfortunately I am new to this and dont quite follow your suggestion, I have the following programmer - KeeYees SOP8 SOIC8 Test Clip for EEPROM 25CXX / 24CXX + CH341A 24 25 Series EEPROM Flash BIOS USB Programmer
                    I am using RT809F Serial ISP Programmer software version 20190508 and cannot find my programmer listed in the supported devices, do you know how to get that working or what other software I should be using?
                    • FeerBaron
                      • Sep 2018
                      • 39
                      You need a WSON8 clip unfortunately. SOIC/SOP8 only covers the backup chip. I found out there are 2 bios on the board. For that programmer I think As programmer software will work.
                      • techrecycle
                        • Jan 2024
                        • 51
                        • england
                        please remove bios password
                        i tried with lenovo patcher but nothing happened
                        SR: 1S20XXS3LB1HPF3NLXPJ
                        thinkpad carbon x1 9th gen
                        thanks in advance
                        • Gangubasus
                          • Aug 2024
                          • 20
                          • Russia
                          Hello! Please help me fix the BIOS. The laptop does not boot, black screen.
                          X1 carbon gen 9
                          20XX-S00PS00
                          PF-2ZJB6Q
                          • Gangubasus
                            • Aug 2024
                            • 20
                            • Russia
                            X1 carbon gen 9
                            20XX-S00PS00
                            PF-2ZJB6Q
                            bump
                            • MaxonDomkrat
                              Lenovo Thinkpad X1 carbon 11th Gen BIOS problem
                              by MaxonDomkrat
                              Hi everyone.
                              I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES – Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...
                              07-30-2025, 01:27 PM
                            • lucaszmn
                              by lucaszmn
                              Problem:
                              Initial Findings:
                              • I concluded that the
                              08-12-2025, 03:01 PM
                            • Gangubasus
                              lenovo thinkpad x1 carbon gen 12 bios damp
                              by Gangubasus
                              Model 21KC-FVT001
                              S/N PF-4CQ9FG
                              CPU genuine intel(r) cpu 0000
                              BIOS N3YET06C (0.06)
                              Hello! I need help getting a modified BIOS for my system. Since I have an engineering processor, is it possible to add the microcode of this engineering processor to the latest BIOS for this laptop model? I think since the BIOS is old, that's why the Wi-Fi driver is not installed on Win10 and Win11, the sound is not adjusted (error code 10 in the device manager) and the screen brightness. The laptop also has BIOS chips W25Q512NW and W25Q128JV, how can...
                              03-01-2025, 01:25 AM
                            • erico
                              Lenovo X1 Carbon BIOS not getting voltage
                              by erico
                              First of all, ive veen reading these forums for some time and its always veen very helpful, so i thank you all for this amazing comunity.
                              I have a lmq-2 13268-1 motherboard from a lenovo x1 carbon 3rd gen. And the MX25l12873f (U49) bios pin 8 is not getting voltage.
                              So far these are my diagnostics:
                              When given 19v trough power adapter, consumption reads 0.003 amps for about 5 seconds then nothing.
                              When power button pressed same result, and i get three green blinking lights from the pwr btn led. But foesnt turn on.
                              If i plug the battery...
                              05-02-2024, 02:40 AM
                            • jendkkd jeje
                              Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                              by jendkkd jeje
                              So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                              I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                              10-11-2024, 03:12 PM
