Dell latitude 3440 reset password
    There is no suffix…
      DELL 3440
      QUAKEL14_RPL /213247-1
      Service Tag : G04JND3
      Work bios locked
        Originally posted by donal310 View Post
        DELL 3440
        Work bios locked
        try and feedback
          Originally posted by LBTT1121 View Post
          try and feedback
          Did not work, only consuming 80-90 ma
            DELL latitude 3440
            Intel i7
            Service Tag : 3KGSMX3
            System: #3KGSMX3-8FC8
            1. 25RH256 check ID OK
            2. 25RH256 read with TL-48 programmer
            (gave check id error) and abort
            with check id disabled read twice OK
            but data was extra at the end by 1KB
            file was thereafter truncated to match size
            data in Hex Editor seems to be apparent with other similar BIOS
            (Possible its just to T48 software that needed an update)
            3. Updated T48 software and check id error no longer present but still an extra 1KB
            BIOS has password which needs resetting
            Thanks in advance
              Originally posted by RodneyW View Post
              DELL latitude 3440
              Intel i7
              Thanks in advance
              The bios chip must be unsoldered from the board before writing or reading..
              do not use the clip, you may have errors..if you do not have anything to unsolder it with,
              solder wires between the programmer and the bios chip..
              and post again..
                and post again..
                Hi, I have exactly de soldered the IC and cleaned it well. The data that is read seemed intact but larger by 1KB and seemed arbitrarily larger. Are you stating that my read is bad and what about it makes you state that?
                  and post again..
                  Hi I read the IC one more time today. I think the issue was from within the T48 software upon saving the data I changed Buffer from Default to Flash only - Never needed to do that.
                    try..
                      try..
                      Thanks, it is working well.
                        GOOD EVENING EVERYONE CAN YOU ELP ME I LOSTE THE ORIGINAL BIOS OF MY DELL 3440 QUAKEL14_RPL 213247-1 SERVICE TAG JR86LS3
                        THANK YOU
