msi CR640 Bios
    msi CR640 Bios
    need msi CR640 Bios file.
    Re: msi CR640 Bios
    here it is. and if you explain the case that would be great. I am very experienced on MSI.
      Re: msi CR640 Bios
      the problem is,
      when i turn on the laptop it directly enters into bios.
      tried on changing hdd, row motherboard etc. i think maybe its a bios issue and that's why i wanted to reprogram the bios. i found the bios chip is 4 mb but your file is 2 mb. what to do?
        Re: msi CR640 Bios
        check cmos battery
          Re: msi CR640 Bios
          Originally posted by masud View Post
          the problem is,
          write it up
            Re: msi CR640 Bios
            its bad when the file its bigger
              Re: msi CR640 Bios
              it looks like BIOS key is keeping pressed itself.
              remove keyboard & test it.
                Re: msi CR640 Bios
                in startup motherboard is checking for bootable devices and if it can't find them, drops to BIOS settings by itself, if you already checked for sata & usb voltages your problem seems to be the HM55 north chip.
