Dell Latitude 5500
  • 11profit
    • Feb 2023
    • 36
    • Poland
    Dell Latitude 5500
    Hi, I have a problem. I updated the BIOS through Windows Update, and now my laptop won't start. Could someone take a look at these files? I would be very grateful, and thank you in advance for your help.
    Model: P80F
    Service Tag: DD4WXY2
  • volinakis
    • Jan 2021
    • 2733
    • N/A
    read bios chipsets again 2-3 times and compare results in HxD, if they are the same you have a good dump. your 25Q80 is empty and 25Q256 it has no volumes.
    • 11profit
      • Feb 2023
      • 36
      • Poland
      What about now:
      • volinakis
        • Jan 2021
        • 2733
        • N/A
        Originally posted by 11profit
        What about now:
        nope, same thing, look at the picture.
        • 11profit
          • Feb 2023
          • 36
          • Poland
          Weird, maybe you have bios bin, for this model?
          • kalilinux25
            • Mar 2018
            • 2089
            • ZAMBOANGA SIBUGAY
            post your motherboard model please
            • 11profit
              • Feb 2023
              • 36
              • Poland
              EDC50 LA-G901P
              Rev: 1.0 (A00)
              2019-03-28
              • kalilinux25
                • Mar 2018
                • 2089
                • ZAMBOANGA SIBUGAY
                EDC50 LA-G901P
                Rev: 1.0 (A00)
                2019-03-28
                TEST AND REPORT
                • 11profit
                  • Feb 2023
                  • 36
                  • Poland
                  TEST AND REPORT
                  Works! But have setup password.
                  • 11profit
                    • Feb 2023
                    • 36
                    • Poland
                    System number is: 805BYY2-8FC8
                    • SI3MAR2000
                      • Apr 2018
                      • 49
                      • MOROCCO
                      plz,I need bin bios of DELL Latitude 5500.ST(S/N):JYFC9Y2(i dont have backup).
                      • Expired
                        • Feb 2023
                        • 34
                        Try password
                        Code:
                        rrrrrznn
                        Code:
                        * FOR SOME DELL CODES PRESS CTRL-ENTER, NOT ENTER, WHEN ENTERING CODE INTO THE BIOS
                        • bykanovm
                          • Aug 2022
                          • 95
                          • Украина
                          I'll write in this thread because the problem is similar, only the BIOS was damaged for a different reason. Module DELL Latitude 5500 ST:GZW52Z2
                          I tried to remove the password using a patcher that I have and works on many models. But apparently something went wrong, and when turned on with the patched BIOS, the laptop turned on, turned the fan, but the image never appeared. I tried to flash the original BIOS, but with it the laptop also does not provide an image. It turns on, the keyboard backlight is on, the consumption is about 1A, then the laptop turns off, the keyboard backlight turns off, the consumption drops, but the power button lights up white. After which the laptop no longer responds to the button until you disconnect the BIOS battery. Maybe someone can fix the BIOS, perhaps my original one was treated with an error, maybe when starting with a patched BIOS, commands were written to other flash drives. Motherboard LA-G902P Rev 1.0
                          My original read dump​
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11735
                            Latitude 5500
                            Service Tag: GZW52Z2
                            • bykanovm
                              • Aug 2022
                              • 95
                              • Украина
                              With your BIOS, the laptop does not turn on at all. I also found another BIOS on another forum, as they say it works, but the ME region has not been cleaned. With it, the laptop does not turn on as well as with your BIOS. When you press the button, the consumption changes slightly, quite a bit from 0.02A to 0.03A with each press. Is it possible that my patched BIOS, created based on the original, corrupted the firmware in other microcircuits during the first boot?
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11735
                                Look for hardware issues, you may have accidentally damaged it
                                • bykanovm
                                  • Aug 2022
                                  • 95
                                  • Украина
                                  I doubt that something happened to the iron. I didn't even take the board out of the case. I'll make a correction, with another BIOS, which I also downloaded, the laptop also turns on but without an image. For the sake of experimentation, I erased the UT6 flash drive, the laptop started turning on but without an image. It won't turn on at all with your BIOS. Is it possible to corrupt the firmware in other flash drives? At startup, perhaps they are recording from the main one?
                                  Amendment. With your BIOS, the laptop behaves the same as with the original one. It turns on, the keyboard backlight is on for about a minute, then it turns off and the light on the power button is on, but there is no consumption. After the button goes out, the laptop does not respond to it until you turn off and reconnect the power supply. Может это из-за отсутствия АКБ ? Но ноутбук с оригинальным боисом без АКБ включался.
                                  Let me clarify, I have a version of the board with a discrete video card.
                                  • spurki
                                    • Apr 2020
                                    • 43
                                    • romania
                                    Can someone please help me to remove bios password? dell latitude 5500 Service tag HPRP2X2,thank you!
                                    • LBTT1121
                                      • Nov 2024
                                      • 528
                                      • Việt Nam
                                      hi, check and feedback
                                      • spurki
                                        • Apr 2020
                                        • 43
                                        • romania
                                        not working cooler spins fast...and nothing else...
                                          DELL Latitude 5500 Notebook 5000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 5500 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5500 boardview and 5500 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5500...
                                          09-06-2024, 12:36 PM
                                          09-06-2024, 12:20 PM
                                          09-06-2024, 12:13 PM
