DELL ALIENWARE M16 R1 Bios Dump needed
    Hello guys i have a dell Alien ware m16 R1 that has boot loop.
    It displays alien ware log then goes off and the sequence repeats its self.
    board number: 213260-1 INFINITY RPL-HX+NV-P
    S/N/ Service Tag: 3RZ0FS3
    Reg model: P124F
    Old file is attached
    i need your help guys
    thanks
    try. let it run for 2 mins, it will restart several time with no image.
      with this dump the machine acts as if completely dead. nothing happens no fan spin no nothing
        check soldering, bios is a virgin one from update and with clean ME.
          man i have tried this file so many times and it doesn't work trust me.
          when i solder its original back up again it works just the same way it was. so the problem ain't soldering bro.
          kindly help me with another file
          patiently waiting
            patiently waiting
            ok, try this only clean ME version, in previous one I was updating bios region to 1.12, also ME to 16.1.27.2225.
              Now this boots well but still looks like the bios has a problem
              it doesn't load completely like its kinda half
              it repeats the restart sequence all over again.
              meaning the Me region is okay but the bios region has an issue
              kindly help bro
                try an older bios version. In your dump it says is ver.1.02 but it doesn't exist in bios updates.
                  with this dump, its dead again😪
                    there are 4 bios images in extracted update bios, try them all. I assumed that your bios is InfinityRplHx_MB2_18_MP because of data I found in your dump, but maybe it was a failed bios update from windows updates and is wrong.
                      hello, i don't see any attachment here except for the photo
                      sorry seen them
                      let me try and give feed back
                        i have tried and tested all these three and non-is giving me results. they all behave like the board is dead
                        need more help please
                          lets try and post result ,,, make sure for original bios chip not change
                            Yes yes
                            finally this worked like charm
                            just entered the service tag and everything came to normal
                            thanks you so much bro
                            thanks 😁😁😂😂😂😂🤣🤣🤣
                              Yes yes
                              thanks 😁😁😂😂😂😂🤣🤣🤣
                              Great......
                                Yes yes
                                thanks 😁😁😂😂😂😂🤣🤣🤣
                                Who bios archive worked?
                                  hello, help me find the bios for DELL Dell Alienware m16 R1 MB ( 213260-1 INFINITY RPL-HX+NV-P )
                                  ST H747LS3
                                  those on the forum do not work
                                    SMDFlea commented
                                    Editing a comment
                                    Thread merged.Please make use of the forum search before posting to find related threads where you can post your request.You do not need to start a new thread every time.
                                  Hello try ...
                                    thanks, bios works
                                      Hello, I'm glad to hear that it helps, although I didn't think so...
