Hello, can someone help me with the bios from HP 15-DW0034NW? LA-H323P REV motherboard 1.0 . On the I5-8gen CPU board. I don't have the original because the SPI memory is completely damaged. Regards
Hp 15-dw0034nw
https://www.badcaps.net/donate -
HP Notebook - 15-dw0034nwAttached Files↵
https://www.badcaps.net/donateComment
This specification for the Acer Extensa EX2540-56BF + PowerCube Original Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EX2540-56BF + PowerCube Original boardview and EX2540-56BF + PowerCube Original schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...09-06-2024, 08:16 AM
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by momolarHello,
I have 2 motherboards for HP Elitebook 850 G8.
Motherboard model: Corvette-6050A3216701-MB-A01
After trying to remove the BIOS password by reflashing BIOS, the first board fails to boot. I then reflashed the original BIOS / EC back, but no success. I don't know if I damaged the board or if the dumps are bad.
I bought the second motherboard as a replacement but it seems to have same issue somehow.
Curiously, when I try to boot without RAM, I get the expected 3,2 error flash code "missing RAM". Everything is normal until... -
by TomyleeHi everyone,
Sorry for the person who’s going to read all this !
I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the... -
by EbrahimSiamiHello everyone,
I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
**Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
**What I have tried so far:**
1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...-
Channel: BIOS Requests ONLY!
07-02-2025, 02:31 PM -
- Loading...
