finding a replacement BIOS flash chip as backup for repair.
  • meanderer
    • Jul 2010
    • 50
    I am looking at a SONY VAIO laptop motherboard that may have a corrupted BIOS and after some research (squinting hard on the motherboard components) I found a flash chip. It is Eon EN25F80-75HCP.
    some spec include 100Mhz max clock speed, 2.7-3.6V input voltage, and 4K page of 256 bytes, etc.
    I can't find a suitable replacement on digikey or mouser with exact specs. If anyone can help locate a vendor with good parts that would be great.
    If I must choose a different value for some of the specs what can I change and expect that it still work? I imagine that I have to keep clock rating and voltage exact, how about memory page configurations?
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: finding a replacement BIOS flash chip as backup for repair.
    See page 32. - Other variations of that PN might work too.
    Mann-Made Global Warming.
    - Dr Seuss
    • meanderer
      • Jul 2010
      • 50
      Thanks, I have seen that datasheet. I need a vendor for this part, both digikey and mouser don't carry it.
      • dobber
        • Jul 2008
        • 83
        If you cant find it, you could go to ebay and find a bad board for cheap that has it on it. I have had to do that before, with other chips.
        PS did you try a Crisis Bios Recovery Disk? you may be able to just reflash it.
        • kikkoman
          • Jul 2007
          • 691
          this (among many other) should work:
          http://search.digikey.com/scripts/Dk...25Q80BVSSIG-ND
          your original part has 75MHz max. clock speed, so there are plenty of alternatives.
          "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
          • testaccgta
            Unable to verify IC or write/erase/flash BIOS file to XMC QH128AHIG SPI chip using NeoProgrammer/AsProgrammer
            by testaccgta
            Hi, everyone!
            I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
            I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...
            09-01-2024, 08:24 PM
          • thxd43
            Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
            by thxd43
            Hello, first of all, excuse me, I am using the translator, English is not my native language.
            I have a Lenovo ideapad 330S - 14IKB laptop.
            The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
            02-23-2023, 08:37 PM
          • acedogblast
            by acedogblast
            11-02-2024, 05:13 PM
            Common SPI bios chip programming Questions and Answers
            by SMDFlea
            Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
            A: If you can`t read from it how do you expect to write to it ?.
            Q: Why is my bios chip unreadable ?.
            A: The programmer is faulty or has a worn or broken zif socket.
            The USB cable is frayed,connector pins worn or some other physical damage.
            Not enough amperage or voltage to power the programmer properly.
            Bad...
            09-02-2021, 04:40 PM
          • inck243
            Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
            by inck243
            Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
            The BIOS...
            07-25-2024, 09:17 AM
