HP Elitebook 645 G10 BAD BIOS
  • minhdigital
    replied
    Originally posted by madjid911
    Hello, thank you for sharing, I have the same laptop with password, I flashed this one, it worked no more password on the other hand it is blocked in manufacturing mode, can you tell me what is the DMI so that I can modify the bios with the original DMI please, or unlock my bios if it is simpler, because RCUNLOCK does not work with 32MB
    HP 645 G10 SERIAL 5CD347C1TD
    Send to you, try !!
  • madjid911
    replied
    Originally posted by hoaca388
    HP EliteBook 645 14 inch G10 Notebook PC
    CTNumber_6MBME0NWYIU0II
    Serial_5CD351K5LJ
    Sku_8J038EC#ABF
    Build Id_23WWKNBZ602#SABF#DABF
    Fearture byte_476J6S6b7B7H7M7Q7W7m7saBaEapaqauawcAeMfPgSguhKjhk8mEmVn7nWpDpnpqprqMqz.tY
  • Allan Larson
    replied
    Serial_5CD351K5LJ
    Sku_8J038EC#ABF
    What method did you use to unlock this? I'm using RCUnlocker and it says I need to use a 16MB chip but this 32MB W25Q256JV chip is the only one I see. Thanks!
  • shiriff47
    replied
    Serial_5CD351K5LJ
    Sku_8J038EC#ABF
    Thank you very much i found the solution.
    i will try to learn by comparing your unlocked dump with my locked one
    Thanks again
  • hoaca388
    replied
    Originally posted by shiriff47
    Can anyone help me to unlock hp EliteBook 645 G10
    motherboard : DA0X9TMB8D1 REV D
    S/N : 5CD351K5LJ
    Serial_5CD351K5LJ
    Sku_8J038EC#ABF
  • shiriff47
    replied
    S/N : 5CD351K5LJ
    commented on 's reply
    Please do not offer any help to members if they have not posted the serial number
    You MUST:
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
  • alfredposadas09
    replied
    Originally posted by alfredposadas09
    after flash first boot go to bios press f10 then reset default settings.. if u don't do this the password will not be remove
    flash it again and follow this steps
  • alfredposadas09
    replied
    Originally posted by Muhammad Faizan
    After all I enter in th bios why password appear again how
  • Muhammad Faizan
    replied
    just flash the winbond dont touch the gigadevice
  • Muhammad Faizan
    replied
    ok tomorrow i will check and update you
  • alfredposadas09
    replied
    hi master
    This is my HP EliteBook 655 G10 in bios password can any one unlock my laptop?
  • Muhammad Faizan
    replied
    hi master
  • RWS93
    replied
    Ok sorted. 22ohm resistor worked fine. Machine runs on original BIOS. I will later try the BIOS provided above to unlock it.
  • RWS93
    replied
    OK so I am an absolute idiot. I do hot air soldering very often but turns out this time I made a mistake. I allowed the idea for this in my head and I started thinking I could knock a component off. I could not find a schematic or board view but I found HP YT channel where they are posting maintenance videos about their machines. There was a picture of the motherboard. On this picture ROM is installed in some sort of a socket unlike on my board where it is soldered but everything else is the same. I noticed I must have knocked off a resistor when desoldering the chip. This resistor has been connected to pin 1 of the ROM. I found that on the other side of the track the voltage goes up to 3.3V max so I decided to replace the resistor with a soldered bridge. After doing so on original BIOS picture laptop wakes up. Keyboard backlight turns ON, power LED turns ON, all the voltages on the board are present, CPU getting warm but no display backlight and no picture. After about 10 sec the machine restarts.
    I guess the bridge is not enough and replacing that resistor is essential. There is no board view no schematic so I do not know the value of the resistor. I found schematics for other laptops with similar ROM and design with the resistor connected to pin 1. Normally these resistors are within 22 - 220 ohm. I will give it a go later today. Any other ideas on the resistor value? Thank you.
  • RWS93
    replied
    Ah I think I understand now. Is it the security register? In AsProgrammer it does not show after I detect the chip... but in NeoProgrammer it does. It is called "security register1". It is exactly of the size 1KB - the extra data at the beginning of your BIOS you prepared for me. Hmmm maybe I just used AsProgrammer initially to work with this laptop and erased the whole chip including the security register. But when making a backup it did not read the security register as my original images are only 32 768KB? Later I wrote just the backup 32 768KB leaving the security register empty? And this is why it won't boot? Hmmm... I took that 1KB of the BIOS you provided and wrote it to the "security register" of the chip. Now the main BIOS image goes in the 32 768KB part. Will see... hopefully this will sort the issue. I think it is quite a logical reasoning here.
  • RWS93
    replied
    Originally posted by danito
    try
    Thank you very much for preparing this image for me. It seems like it is bigger than the original .bin: 32.769 KB (your image) vs 32.768 KB (original image). Maybe the difference is in the first bytes of the file as I showed in the screenshot?
  • danito
    replied
    Originally posted by RWS93
    I am having problems with the following laptop:
    Could anyone please help?
    try
  • RWS93
    replied
    Brand: HP
    Model: Elitebook 645 G10
    Motherboard model: DA0X9TMB8D1 REV: D
    It is an AMD 7000 series CPU laptop.
    The problem is this: computer has came with BIOS password and also Windows locked to a company domain. I have done what I would normally do in such case:
    1. Desoldered BIOS chip
    2. Put it into the programmer
    3. Made two .bin backups of original bios
    4. I found a fresh BIOS image on the internet
    5. Write the new fresh BIOS image to the machine
    After I have done this the machine would not boot. It starts automatically when power is plugged in then:
    1. F5 key LED lights up Orange
    2. Power LED flashes White/Orange
    3. Machine turns on and off like this a few times
    4. Finally the F5 key LED turns off and the Power LED stays white
    5. If I press power button in such condition I get 7 flashes on the CapsLock LED
    6. Laptop reacts to the power button: if I press it long enough the machine turns off but then turns ON automatically and the cycle repeats
    Under such condition I can see voltages on the motherboard going up: 3.3v, 5v are ON all the time. For a second or two I do get 1.8v for RAM and one of the CPU power stages (the high resistance one) goes up to 0.8v. Later these voltages go down and only 3.3v and 5v remain ON.
    I thought this was just a corrupted image I downloaded from the internet. So I written back the original image. After soldering the chip back to the laptop I still get the same issues as described above. Power light flashing white / orange, Caps Lock LED flashing 7 times. Same voltages on the board.
    I have checked the BIOS chip few times and it is programming and verifying fine each time. The soldering is done right: chip is always soldered back correctly with all the pins making contact. No components has been blowed off the board with hot air. Soldering has been done very carefully. I do not think my original BIOS would be corrupted. It has been read on two different computers but using same programmer (I have made two copies).
    What could be the problem? I have seen on another forum someone having simillar problems with G8 and repaired by flashing the EC ROM.
    I have attached both images of BIOS and EC ROM.
  • Wutru
    HP Elitebook 820 G4 BIOS repair assistance required
    by Wutru
    Hi guys,
    If someone would be able to provide some expertise, I'd be very grateful.
    BIOS Corruption - Cause
    So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
    After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
    09-06-2025, 10:32 AM
  • STKR123
    The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
    by STKR123
    Greetings badcaps community,
    I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
    So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
    Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
    I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
    These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
    I learned that desoldering...
    10-29-2024, 06:03 AM
  • macabook
    by macabook
    🧩 Initial Issue
    07-24-2025, 02:17 PM
  • Guest
    Elitebook 850 G5 BIOS bricked
    by Guest
    I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
    I assume the BIOS update failed, so I searched for the BIOS chip.
    I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
    However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
    Can the corrupted...
    03-24-2025, 01:21 AM
  • Vesko356
    by Vesko356
    08-11-2023, 03:27 AM
