ASUS ROG GX531GWR Bios Request
  • danlopez1222
    • May 2022
    • 13
    Here's a weird one- Device refuses to recognize USB 2.0 devices. Will see USB 3.0 devices and hubs, but nothing USB 2.0. Intel ME problem? Seems to be ok with the internal Bluetooth because it is running USB 1.1.
    Model: GX531GW-AB76
    Serial: K5NRCV01Y83320C
  • virginlulu
    • Feb 2019
    • 21
    • China
    Re: ASUS ROG GX531GWR Bios Request
    Originally posted by danlopez1222
    here's a weird one- device refuses to recognize usb 2.0 devices. Will see usb 3.0 devices and hubs, but nothing usb 2.0. Intel me problem? Seems to be ok with the internal bluetooth because it is running usb 1.1.
    Model: Gx531gw-ab76
    serial: K5nrcv01y83320c
    100% ok bios
    • danlopez1222
      • May 2022
      • 13
      Originally posted by virginlulu
      100% ok bios
      This didn't fix it, looks like it is a PCH failure. All USB 2 links seem to have died somehow. I'll try again after the part come in.
      • virginlulu
        • Feb 2019
        • 21
        • China
        you are right!
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • pirati
          by pirati
          10-27-2025, 04:20 PM
        • grimacelord
          by grimacelord
          07-10-2025, 02:52 PM
        • cr4zychriss
          by cr4zychriss
          • Rebrand: PC Specialist
          11-14-2025, 04:04 PM
        • touftaf7301
          ASUS TUF A17 – BIOS password removal request
          by touftaf7301
          I have an ASUS TUF A17 (model TUF707NV-HX088W, motherboard NJS / DA0NJSMBAF0 Rev F) that is locked by an UEFI BIOS password.
          I have already checked the BIOS guides, methods, resources and tools section but could not find a working method for this specific model.
          Details:
          – Make/Model: ASUS TUF A17 TUF707NV-HX088W
          – Motherboard: NJS / DA0NJSMBAF0 Rev F
          – Serial number: S7NRCX05W03829E
          – Issue: UEFI BIOS password locked (no access to BIOS setup or boot options)
          – BIOS dump attached below (read with RT809F)...
          11-07-2025, 02:15 PM
