i use this bios and the laptop turn on but stuck at security controller.
can someone help? hereby i attached my bios and ec backup but if i use this backup the laptop cannot turn on only flash at caps lock.
my serial number : 5CG1163FDR
PROD ID: 3V360PA#AR6
already edited the serial number and prod id. now the laptop is normal.
thanks for all
can someone help me.
this bios work for me but i cannot find the serial number and prod id in the bios to edit.
the original bios is empty so i flash the bios with this file.
my hard drive is broken so my last working file that i can edit the serial number is gone.
my serial number that i want to edit is:
SN = 5CG1163FW1
PROD ID = 3V360PA#AR6
finally succeded edit the serial number using BCU but still get error for CT Number. is there a way to find the CT number because there is no sign of sticker on the board for the CT Number
CT Number_6LGWQ0DWYF0CTR
---------------------------------------------------------------------------------------------------------------------------------------------------------- All donations to Badcaps are welcome. Become a Badcaps supporter >>>>>click on this link to donate <<<<< Thanks to all supporters.
hi hoaca388, thanks for the help.
after setconfig i get errors. and after restart the computer the warning for CT Number is gone but show like in the picture i attached.
can you tell me how to get the CT Number? because i cannot found on partsurfer
hi @ bamboofuto hanks for the help.
HP ProBook 635 Aero G7 please fix my bios no video
Motherboard: LINDEN-6050A3147201-MB-A01(A1)
PrordID: 2W8R4EA#ABZ
SN: 5CG11338Y5
I attach bios
thanks to all
CT number and SKU is in the Info.txt file at # 50.
came in dead, flash bios, done. a week later the customer said the laptop display bios update when turn on and after that dead no display. always show led 7 times on capslock.
i have tried to flash the bios again and everything ok. but couple days later i got the same problem. when turn on it shows HP endpoint security controller problem. when click ok show bios update and dead no display again.
can someone check the bios if there is a problem with it?
