HP Probook 635 Aero G7 Endpoint Security Controller Problem
  • Matteo Setti
    • Apr 2024
    • 12
    • Italia
    Originally posted by alfredposadas09
    try this .. make sure u dont switch the bios chips otherwise it wont work
    Thanks alfredposadas09​, but even the latest firmwares were not conclusive. The caps lock button keeps blinking 7 times every time I try to press the power button. With HxD I tried to see the new versions of the firmware you shared with me, but I didn't understand the changes you made.
    • Matteo Setti
      • Apr 2024
      • 12
      • Italia
      alfredposadas09​ thanks to your firmware I managed to resurrect the laptop!
      I made several attempts and solved that with a more precise soldering of the EC chip.
      I still have a problem with the (Italian) keyboard, which now doesn't recognize some keys (enter, T, Y, Z, X), could it be due to the firmware?
      Once bitlocker was disabled I also installed the new firmware of HP 01.16.
      • alfredposadas09
        • Aug 2020
        • 343
        • Philippines
        try another keyboard
        • Kazuhira
          • Mar 2024
          • 8
          • Japan
          My ProBook 635 Aero G7 also has the "Endpoint Security Controller Problem".
          Can anyone help me?​
          P/N:2K5P6PA#ABJ
          S/N:5CG102BQWY
          Build ID:20WWGZAT601#SABJ#DABJ
          Feature Byte:
          3X476S6b7B7H7M7Q7W7m7saBapaqauawbUbhcAdUdpdqfPguhKjhk8mE.dH
          • danito
            • Jun 2016
            • 890
            • Romania
            P/N:2K5P6PA#ABJ
            S/N:5CG102BQWY
            Feature Byte:
            put your backup bios.
            • Kazuhira
              • Mar 2024
              • 8
              • Japan
              #26
              I was able to find a solution on my own.
              Thank you.
              • SirWilliam
                • Jul 2024
                • Italia
                #27
                Sorry to bother you Matteo, I need to know few things about the way you solved: may I ask you ?
                • jithinkn
                  • Jul 2018
                  • 34
                  • UAE
                  #28
                  ProdID:443V8PA#ABJ
                  SN: 5CG1241VKB
                    • 20619
                    ProdID:443V8PA#ABJ
                    SN: 5CG1241VKB
                    Try https://www.badcaps.net/forum/troubl...er#post3310855
                    • lauri61
                      • Jul 2015
                      • italia
                      #30
                      hp probook 635aereo g7
                      serial 5cg10172n9
                      System is booting in Manufacturing Program Mode
                      • peste
                        peste commented
                        Editing a comment
                        merged post..
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11573
                      • Viet Nam
                      #31
                      serial 5cg10172n9
                      HP ProBook 635 Aero G7 Notebook PC (2W8R7EA)
                      • asdasd1992
                        • Sep 2022
                        • philippines
                        #32
                        HP ProBook 635 Aero G7 Notebook PC (2W8R7EA)[/QUOTE]
                        Tested working file thanks hoaca388
                        • bamboofuto
                          • Nov 2022
                          • 53
                          • indonesia
                          #33
                          i always get error on verifying. i mean the the programming flash was succeded but the verifying flash always error address 0x00bc8 buf_val:0x316B IC_Val:0x306B.
                          i use XGPro version 12.67 with TL866II-Plus.
                          does anyone know how this is happened?
                          • peste
                            • Dec 2016
                            • 12569
                            • ROMANIA
                            #34
                            remove the bios chip from the board, put it in the adapter and the adapter in the programmer.. if you use the clip you will have errors.. or stick wires between the programmer and the chip..
                            • bamboofuto
                              • Nov 2022
                              • 53
                              • indonesia
                              #35
                              hi peste, thanks for the reply.
                              i did remove the chip before and do the flashing with TL866II-Plus. before flashing i did backup the BIOS chip and EC chip and succeded. but when i tried to do flashing for both chip they all failed.
                              • peste
                                • Dec 2016
                                • 12569
                                • ROMANIA
                                #36
                                the bios chip does not make firm contact with the adapter, flux paste is probably left on the terminals, scrape the chip terminals with an abrasive tape..
                                • bamboofuto
                                  • Nov 2022
                                  • 53
                                  • indonesia
                                  #37
                                  Hi peste
                                  i did clean allthe connector inside the TL866II-Plus and the adapter pin but still get error.
                                  i also use a new bios chip but still get error.
                                  P.S everything okay when i use tool for flashing another laptop bios
                                  • peste
                                    • Dec 2016
                                    • 12569
                                    • ROMANIA
                                    #38
                                    Hi peste
                                    uncheck verify after..
                                    • bamboofuto
                                      • Nov 2022
                                      • 53
                                      • indonesia
                                      #39
                                      i did the verifying after programming it says like attachment
                                      • bamboofuto
                                        • Nov 2022
                                        • 53
                                        • indonesia
                                        #40
                                        Are these ok ?
                                        i use this bios and the laptop turn on but stuck at security controller.
                                        can someone help? hereby i attached my bios and ec backup but if i use this backup the laptop cannot turn on only flash at caps lock.
                                        my serial number : 5CG1163FDR
                                        PROD ID: 3V360PA#AR6
                                        • fede77
                                          Problem with the HP Endpoint Security Controller - HP ProBook 450 G8
                                          by fede77
                                          Notebook HP ProBook 450 G8
                                          ProdID 2K8L1LT#AC8
                                          Mother: DAX8QAMB8D0 REV D
                                          The device had bootloop issues. I reprogrammed the EC BIOS and the main BIOS, extracted from an HP 440 G8 with the same motherboard, and I was able to start the device. However, every time I turn it on, I get the error 'There is a problem with the HP Endpoint Security Controller in the unit.' I tried disabling several security options in the BIOS, but the error still appears. Additionally, when I attempt to update the BIOS, both BIOS chips get corrupted again....
                                          03-10-2025, 07:12 AM
                                        • jmp9155
                                          i have hp probook 640 g4 stucks hp endpoint security controller
                                          by jmp9155
                                          accidentally after the upgrade to 1.28 suddenbly my i hp probook 640 g4 stucks hp endpoint security controller i already downgrade the bios to 1.15 still the same and again revert back to 1.28.
                                          any solution for this issue?
                                          07-09-2024, 06:23 AM
                                        • kolebbk
                                          HP EliteDesk 705 G5 SFF (AMD) - Endpoint security controller problem
                                          by kolebbk
                                          Hi, I have a problem with my HP EliteDesk 705 G5 Small Form Factor computer on amd . Standard corrupted bios probably corrupted during the update. I have uploaded a clean dump from the manufacturer's website with the latest version but when I turn it on a message appears :
                                          HP Endpoint Security Controller problem
                                          there is a problem with the hp endpoint security controller on the unit
                                          I tried restoring the bios security to factory defaults after the first switch-on because this helps with intel-based laptops. Here unfortunately this did not help. Does anyone have...
                                          09-04-2024, 12:44 AM
                                        • mego1974
                                          HP Probook x360 435 G7 Endpoint Security Controller
                                          by mego1974
                                          Hello
                                          i need help
                                          I have a laptop HP Probook x360 435 G7 with bios password
                                          I succed to remove the password with the RC toll and right now i have this mesage on the scren "HP Endpoint Security Controller Problem " "Please contact the HP.Inc to have the unit serviced".
                                          I have read the both bios chips and i have posted a picture with the chips pozition.
                                          Can anybody help me with intruction or look on the dump if something is wrong ?
                                          Thanks in advance!!
                                          Edit
                                          Serial 5CG03947C4...
                                          12-17-2023, 01:57 PM
                                        • spider300
                                          HP ProBook 430 G8 hp endpoint security controller problem
                                          by spider300
                                          please Help Me ... ProBook 430 G8
                                          HP EndPoint Security Controller Problem...
                                          07-11-2023, 08:40 AM
